Question about Maytag Bravos MTW6600T Top Load Washer
Fault code F51 - Maytag Bravos MTW6600T Top Load Washer
    New Friend:
  • 28 Answers
Please google your problem, it is quite long! Hopfully you are handy!
Posted on Jan 27, 2013
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
What does fault code F51 indicate?
Search the internet for:
Make + Model + the word "F51"
Mar 05, 2016 | Washing Machines
What is Technical Fault 51?
The most common reason for this code is :-
F51 error is caused by a faulty or blocked heater pressure switch. It is not a job for an unqualified person.
"The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes. "
Apr 14, 2015 | Washing Machines
What is f51
On some machines the F51 is a slow or long drain error. Possibly a clogged filter in the drain pump or a bad pump. You did not provide enough information for me to offer any more help. I do not know the washer type, manufacturer, age, or model.
Mar 11, 2015 | Washing Machines
What does F 51 mean?
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Sd 51
In addition to the above tips, check the installation of the drain line. Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board. You will probably need a technician to diagnose and repair one of these component failures in your washer.
Aug 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F 51
Jul 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F51 code
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 17, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
