Question about Denon AVR-2700 Receiver
Connect to Video Component
My old TV has brooken. I then changed my very old tube TV by a flat TV that came with video component and hdmi and DVI connection except by S-Video. However my A/V Digital Receiver has S-Video monitor Out output that is used to display all programming/setup speakers and fiber/digital outputs at TV screen. I do not have plans to change and buy a new receiver as the sound and quality of my receiver and 5.1 audio is good enough.
  • eduardo silva Jan 24, 2013
    Thanks. The yellow video jack from Receiver Monitor Out was connected into the yellow composite video from the TV. It worked well. !!
    Genius:
  • Denon Master
  • 1,054 Answers
Check your receiver. It should also have a single composite video output jack as well. Usually one of the component video inputs on the tv is also labeled for composite use as well.
Posted on Jan 23, 2013
Soulvisitor
  • 1113 Answers
SOURCE: Problem with video signals through AVR-4800
Pic of product.
Owners manual
I'll be back after I study it, if problem persisit
Check monitor 1 settings in the on screen display on tv for me
Cheers
S.
Posted on Jan 14, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
  • 27 Answers
SOURCE: Denon AV Receiver 1706
Do you still have the unit still ??
Posted on Nov 11, 2008
SOURCE: No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Posted on May 25, 2009
  • 441 Answers
SOURCE: how to change the video output on denon avr 486
under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Posted on Jul 16, 2009
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
Just trying to connect the HDMI using a cox cable box. Cannot find the connection on the tv.... help
This TV doesn't have an HDMI port. You can use a DVI to HDMI adapter or the component video. (I assume the Cox cable has component video out.) You will need to connect an audio cable as well. There are 2 DVI-HDCP ports.
I wish that I could be of more help.
Oct 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
How do i connect my laptop to my lcd to watch films off the net
Depending on how old your laptop is, or what make it is, you may have few or several options. Some manufacturers have their own proprietary adapters/dongles for video out, but most at least give you VGA out, and others may have DVI, or the newest: an HDMI connector at the back.
If a proprietary dongle is provided, you're stuck with whatever it is they offer. It could be as poor as composite video (3 leads: yellow, white and red), S-Video (better), or best: component video for HD viewing. The first one offers you standard 640 x 480 definition, at 4:3 viewing ratio, while component offers you 1080i, using three leads to connect your
laptop to the LCD. Fortunately, most LCDs have component connectors. If the latter is available, this would be a great option, provided your LCD supports at least 720p, considered to be HD, though not the highest HD. The highest is 1080p.
Depending where you are in this wide scenario, the main thing is to get your LCD TV (I assume) hooked up the right way. The simplest way is to connect it using VGA, assuming your LCD has VGA as an input option. The next one would be to find an adapter to make the match. eg: DVI to HDMI, or vice versa; or VGA to DVI, etc. However the ideal one would be to have matching connectors at both the laptop and the LCD TV: HDMI to HDMI, or DVI to DVI, or component leads at both ends.
Aug 20, 2009 | Acer AOA150-1178 Notebook
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
66 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
