Question about Abit AW9D-MAX Motherboard
1 long beep in post
As soon as I turn pc on I get one long beep. Pc posts as normal then boots into windows.
  • Abit Master
  • 3,606 Answers
Hello one long beep, is a failing ram module.
Try to renew the modules, or remove the modules, and insert one at the time.
Just to test one of them for fault.
4x 240 Pin DDR2, Dual Channel DDR533//667/800, up to 8 GB
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One short beep is normal.
Good luck
Posted on Jan 24, 2013
5 Suggested Answers
SOURCE: ABit Fatal1ty AA8XE
my pc Fatal1ty AA8XE will not power on
Posted on Dec 11, 2009
19messiah65
  • 230 Answers
SOURCE: when boot, there is a long beep repeating every
This mean that this is a general memory or RAM error or might as well your CPU is overheating. You can try reseating your RAM or CPU, if all else fails try replacing your RAM with a system compatible one.
Posted on May 18, 2010
mace1mace
  • 1138 Answers
SOURCE: abit av8 bios post codes 8.3 - 8.6 - 9.C
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
puertobori
  • 7733 Answers
SOURCE: I get a POST code of 00 then after i hit the power
If no beeps your MOBO is fried.Is no worth to try to fix.Instead i suggest to get a new one.
Posted on Dec 19, 2010
Computer beeps but won't boot
if the beep is continuous it is likely the ram modules have dislodged.
however if it is just the normal short beep you get every time the computer starts normally, then it is just the post beep this simply indicates that the hardware has passed the Power On Self Test or POST for short. this would suggest the issue is windows related more so then hardware related, i would try using a windows 7 recovery or pe disk to boot it from.
Mar 02, 2017 | Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Bios utility
BIOS Setup utility?
Dell laptop?
Lot of information here.......let me see if I can sift through it.........
Post the model number in a Comment.
The model number can be found on the Bottom of the laptop.
As soon as you turn your laptop on, watch for the Dell logo screen.
WATCH the bottom of the screen.
What key does it state to press, to - enter BIOS Setup?
Write it down.
If Windows loads let it load, and run a few minutes. Then turn the laptop off normally.
THIS time AS SOON AS you press the Power On button, start tapping on that BIOS Setup key.
Tap in 2 second intervals.
You may hear beeps. Those are Stuck Key Error Code beeps, and it is you that is doing it. Ignore them.
This will get you into the BIOS Setup utility.
If Windows doesn't load, press the CTRL key, and ALT key, and DELete key, AT THE SAME TIME.
This will restart your laptop, and start tapping on that enter BIOS Setup key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Dell Studio Computers & Internet
I have IBM P3 and i want to change win xp but its not booting pliz help me and it doen't give me option of booting
Turn the computer on. Keep your eyes glued to the bottom of the monitor screen. This usually comes by fast, so keep your eyes peeled.
When the computer manufacturer logo screen comes up, look for the -> enter CMOS Setup, or enter BIOS Setup, <- key to press.
Write it down.
If Windows loads on your computer, allow it to load, and run for a few minutes.
Turn the computer off normally.
WAIT 20 seconds, or so; then turn the computer back on.
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup key. (Or enter CMOS key)
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
Once you get into BIOS. look for Boot Options.
In Boot Options set the first boot device to CDROM.
http://www.hiren.info/pages/bios-boot-cdrom
REMEMBER, you have to Save Changes, or it will be like you have done nothing at all.
Regards,
joecoolvette
Mar 07, 2013 | IBM NetVista PC Desktop
No post
Is not the monitor, its the graphics driver for the windows. you can boot it in safe mode and try to remove the drivers but that seldom works.. The solution is to reformat it again this time DO NOT INSTALL THE GRAPHICS DRIVERS let the system use the windows default.
Dec 27, 2012 | HP Black Pavilion p6-2143w Desktop PC with...
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
How do I bring up the etower 500is in safe mode?
as soon as you see the post screen just as it turns on start pressing F8
Mar 18, 2011 | E-Machines etower 500is PC Desktop
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
Abit AW9D-MAX Motherboard Logo
114 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
