Looking for schematics for a PowerVar Control panel
Uninterruptable Power supply, UPS, PowerVar, ABCE800-11
  • ALFREDO ALANIZ
    ALFREDO ALANIZ Jan 23, 2013
    PowerVar abce800-11 looking for schematics or diagram for the flat ribbon cable to the control panel, I have a unit, but it has no panel, I want to test the unit by probing the cable.
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Intel D865PERLL Motherboard will not power up
Hi nkda2000, this is as close as I could find for power schematics. Intel D865PERL
http://support.intel.com/support/motherboards/desktop/D865PERL/sb/CS-027143.htm
(There is no Intel D865PERLL board). Sure it's a typo. Have done searches for D865PERLL & found it (Not on Intle's web site) but when looking at the specs it's listed as D865PERL. (One L ) not two.
I hope the Technical Product Specification pdf can help you check the power on the motherboard.
Luck!
Mike
Posted on May 08, 2008
After a power cut, when the power comes back on again, the garage door opens up. How can I change this setting? Obviously not great if we aren't home or if it's the middle of the night!
Hi Rachel , Can you find a model number on the door controller unit it will help us to search for a possible idea on the settings side of the solution to your unwanted problem.
Another possible solution may be to use a UPS on the controller. This stands for uninterruptable power supply. However long prolonged power failures may drain the UPS battery but it would work for short power interruptions (time depends on the standby power drain of your door controller and the VA rating of the UPS) and brown outs to the power lines. These are used on computers normally so a search on the internet for UPS or take a visit to a computer shop and they would source or carry a UPS device.
Oct 08, 2014 | Building Materials
Tip
UPS - Battery Fault
UNINTERRUPTABLE POWER SUPPLY
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault. A faulty charging circuit will not charge the batteries and will also cause a fault condition.
Lower powered and cheaper type UPS are switch over types, when the mains supply fails, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power to the computer and peripherals. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
NOTE the power waveform from these UPS is a pseudo sine wave (i.e. not a true sine wave).
The true UPS types are usually the higher KVA units (over 1500 VA) that supply continuous mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power to the computer equipment, therefore there is no switch over time lag when the mains supply fails.
on Dec 02, 2009 | Computers & Internet
Started Flickering and strobing
Intermittent activity may be associated with a disruption of continuity between the power supply and the video circuit board. Commonly the condition was damage from a power surge and for what it is worth; I strongly suggest that if your repair or replace the device; obtain a UPS rated at 1000 Watts. A UPS is a battery backup surge controller. Uninterruptable Power Supplly.
Feb 09, 2014 | Samsung UN50EH5000 50 LED HDTV
Electrical trip switch
Buy a UPS "uninterruptable power supply" from a office supply store. Plug your pump into the UPS. When the power stops, pump will continue to run.
Jan 15, 2014 | Deluxe Car Seat Piddlepad Prevents Stains...
Stupid electronic controllers! Is there ANY way to make it resume 'previous state' after power outage? The **** thing shuts OFF when the power goes out for even a milli-second. As I live...
It won't be cheap because of the power a decent AC demands but an appropriately-sized "on-line" Uninterruptable Power Supply (UPS) supplies power from internal batteries continuously but when AC is available, the batteries are just paralleled to the line so any appliance plugged into the UPS never notices the power failure; at least until the batteries are exhausted. Since you didn't include the make and model, no one can tell you the backup capability you need or which voltage it requires (120 or 220VAC).
Aug 15, 2011 | Samsung AW0803B Air Conditioner
Wat is ups
uninterupted power supply
Jan 09, 2011 | APC Back-UPS 400VA (BK400) UPS System
TV model number is M61WH745 it keeps blowing the blube this will be the 4th one in 5 years
first the correct model # is M61wh74s.
there are two differnet lamps that may have been installed at the time of manufacture. you should remove the lamp access door and use the lamp part # printed on the label pasted to the inside of the access door. To use any other or a sub (which are only good for about a year) will down grade the brill of the picture and cause undue load on the ballast (supply cirucit for the lamp). Additionally if you are in an area that experiences frequent brown outs (power reduction to the home) I strongly suggest using a UPS (uninterruptable power supply) to power your DLP TV.
Jan 02, 2011 | RCA Televison & Video
I WANT TO CONNECT TWO APC UPS 700 VA UNITS TO SINGLE 24 VOLT BATTERY. BY DOING THIS MY INTENTION IS TO CHARGE THER BATTERIES RAPIDLY WHEN THE ELECTRIC SUPPLY IS RESTORED. IS IT POSSIBLE TO CONNECT TWO UPSs...
waheed70, NO!!!! NO!!! NO!!! DO NOT EVEN THINK OF DOING THAT!!! You may cause catastrophic failure to not one but both APC ups units and will void any warranty you might have!!! If you are in need of longer run time on battery back-up, then start looking into buying an "ONLINE" ups system somewhere in the 5 to 10 kva range. Check out "chloride" systems and "powervar" and "toshiba" and "ONEAC" for info about "true online" battery back-up systems. Bye for now. 12fixlouie
May 02, 2010 | APC Smart-UPS 1000VA UPS System
My ups battery backup time is too short even i replace the battery
sounds like you have too many devices plugged in, it's not the ups that's failing it's the amount of power it takes to keep all you devices running. you may want to buy a larger ups or you can unplug some of the devices you don't need in the event of power outage. if it's just your pc your power supply might be sucking up alot of juice, i'd check and see what the power consumption rate is on that particular power supply.
Nov 15, 2009 | Dell Uninterruptable Power Supply, 1500VA,...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
