Question about Airbrush-Depot Master Airbrush Model G23 Airbrushing System With Tc-848 Four-cylinder Piston Air Compressor With Tank
Won't spray air blows out but the paint doesn't come out
    New Friend:
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Posted on Feb 26, 2013
Air conditioner model 585CJ02450 doens't blow out cool air during the day at night blows cool air can I clean the filters and radiator
Was there any resolution? mine does the same it runs blows the fuse, but doesn't blow air out I would have liked to see what your resolution was.
Jul 12, 2012 | Heating & Cooling
Air doesn't blow hard out vents
It's probably just a blockage.
Mar 01, 2012 | 2000 Nissan Xterra
Air Conditioner fan problem. AC fan very noisy and doesn't blow with full power
bushing in motor is probably shot,or some critter put it's nest in there ,either way the motor has to come out.
Jan 11, 2012 | 2003 Chevrolet Malibu
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
I had my front bumper painted and now my ac only blows warm air and the ac compressor will not kick on.
The A/C condenser is mounted right behind the bumper so, unless the painter covered the condenser or removed the bumper before spraying it, he painted the condenser as well. This is bad because the condenser must have air flow through it in order for the A/C to work properly. Try to have a look at the condenser, it looks like a smaller radiator mounted in front of the radiator and behind the grill / bumper. If it is painted, go back to the paint shop and demand it to be replaced. Also, have the radiator checked to be sure it isn't painted because that'll run into engine overheating issues.
May 15, 2011 | 2004 Lincoln Navigator
Temperature gauge fluctuates and the heater blows cold air
Definitely check your fluid level in your radiator. Top it off all the way. I've seen that happen multiple times on cars that were low on anti-freeze. If that doesn't work try replacing your thermostat. It's cheap and the easiest place to start if topping off the fluid doesn't get you fixed up.
Oct 16, 2009 | 1997 Chevrolet Camaro
Airbrush-Depot Master Airbrush Model G23 Airbrushing System With Tc-848 Four-cylinder Piston Air Compressor With Tank Logo
250 people viewed this question
Top Airbrush-Depot Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Airbrush-Depot Craft and Hobby Expert? Answer questions, earn points and help others
