Question about Kitchen Ranges
Range burner will not turn off, the knob is tight and stuck
My knob will not turn the burner off, if I press hard it will strip the knob, the flame will not turn off, it remains on. I had to turn the gas off at the source
Not knowing age - very often older (standing pilot) ranges will have burner valves that become hard to operate. These are usually a tapered core valve that can be greased with a high temperature valve grease.
Posted on Jan 28, 2009
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Gas burner will not stay lit. works fine when pressing knob for igniter function but goes out when knob is released
You have what we call a flame safe device fitted to the burner, (thermocouple lead), have you checked to make sure your flame on the burner is touching the tip of the "probe" on t'couple, if it isn't make sure that the ports on the burner are clear. If this does not solve problem then the thermocouple needs replacing by a Gas Safe engineer.
Oct 25, 2013 | Verona VEFSGG365SS 36" Gas Range with 5...
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
On my range GE Profile XL44, the front burner will not turn off, the flame stays on, the knob is hard to turn and will strip if I press it too hard, I had to turn the gas going to the range.
REMOVE THE KNOB BY PULLING OUT ON IT. LOOK IN THE CENTER OF THE SHAFT THAT THE KNOB GOES ON.....IS IT HOLLOW? CAN YOU SEE A SMALL SCREW HEAD IN THE HOLE? IF SO, YOU CAN TURN THIS SCREW CLOCKWISE FOR MORE FLAME AND COUNTERCLOCKWISE FOR LESS FLAME. YOU WILL NEED A VERY SMALL DIAMETER FLATBLADE SCREWDRIVER FOR THIS ADJUSTMENT AND MAKE SURE YOU PUSH BLADE INTO SCREW SLOT FIRMLY AND TWIST FIRMLY TAKING CARE NOT TO STRIP THE HEAD OF THE SCREW. ALWAYS PERFORM ADJUSTMENT WHILE BURNER IS ON WITH FLAME LOW.
Jan 28, 2009 | Kitchen Ranges
Burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Mar 07, 2008 | Roper FGP325K Gas Kitchen Range
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
729 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
