Question about Epson PowerLite® 83c LCD Projector
Epson 83+ projector has diagonal pink stripe even when disconnected from computer.
In the bottom left section of the image there is a fuzzy pink stripe. The bulb has been replaced. The stripe is there even when disconnected from everything else.
dhiman
  • 115 Answers
SOURCE: projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Posted on Nov 27, 2007
  • 5 Answers
SOURCE: Epson projector issue
I've found my solution. My troubleshooting info said to go to "signal" and make sure that "auto" was turned on. However, I couldn't find "auto" when I first tried. There are two places where signal comes up. The second one is under "set-up" and that is where you turn "auto" on. It works perfectly now. I hope this helps. For the icons, make sure you have "mirror image" turned on in your displays preferences if you're on a Mac. Good luck.
Posted on Jan 06, 2008
  • 110 Answers
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Posted on Aug 22, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
Epson projector center blurry
Sounds dumb on this one but make sure the lens is cleaned. Other then that check the manual for operating range of lens to screen. Typically somewhere in the area of 8 to 12 feet.
Oct 09, 2012 | Epson PowerLite 83 Plus Projector
My Projector color is completely messed up, I have reset it and everything still looks pink.
In the image menu, make sure that your RGB/Component settings are correct. If they are incorrect this will cause a pink tint on the projector.
Oct 26, 2010 | Epson EMP-1715 LCD Projector
My Epson Powerlight starts ok but the images have a pink tinge
Bay chip reset software from ebay or another place
for epson
http://cgi.ebay.in/Printer-Chip-Resetter-for-Epson-Reuse-Your-Cartridge_W0QQitemZ110521839309QQcmdZViewItemQQptZLH_DefaultDomain_203?hash=item19bb9d6ecd
Apr 10, 2010 | Epson PowerLite 62c Multimedia Projector
Epson 3lcd projector projects pink stripes
reset the settings to factory default. the signal does not match.
Nov 10, 2009 | Epson - PowerLite S1+ Multimedia Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Epson powerlite s4 projector is pink
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
EPSON EMP 3000
There is an adjustment in the Video section for adjusting it to look square.
Aug 13, 2008 | Epson ELPSC07 for PowerLite Home 10,...
Epson PowerLite S1+
May 20, 2008 | Epson - PowerLite S1+ Multimedia Projector
ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
Epson PowerLite® 83c LCD Projector Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
