Question about NetGear DM111P ADSL2 DSL Modem
Dm111psp x2 modem goes out many times a day
Sometimes needs to be rebooted and sometimes it comes back on its own.
    Problem Solver:
  • 15 Answers
POWER ADAPTER ISSUE
Posted on Mar 29, 2014
My internet keeps going out. Comes back on when I shut down the modem and reboot. Goes out after not using
1. disconnect all cables and reconnect
2. try factory resetting the router (hold down reset button in back for more than 12 seconds)
3. if it is still happening call your ISP
4. if your ISP does not own the modem then you need to replace it yourself.
Aug 12, 2014 | Computers & Internet
I forgot my password
Reset the modem by removing the power cable from the back of the modem for a full 30 seconds and plugging it back in.
This is sometimes referred to as "power cycling" the modem, and is a good way of clearing network timeouts and other problems that can appear on modems that have been running continuously for some time.
Reset the modem by unplugging the power cord from the electrical outlet or surge protector into which it is plugged.
This is a good alternative to removing the power cord from the back of the modem if it is difficult to get to the modem because of its physical location. Count the full 30 seconds and plug the modem back in to complete the reset.
Reset the modem by pressing the reset button the back of the modem.
The button itself is recessed into a hole to prevent accidental resetting, so you will need a pen or some similar thin utensil that can fit inside the hole.
Press the pen into the hole until you feel the button depress and then let go.
This is sometimes called a "hard reset" or "hard reboot," as this will restore the modem to its factory default settings
Hope this helps
Sep 25, 2012 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I am having a problem with a motorolla modem 221--02-1022 modem seems to be overheating and will often disconnect or not allow me to connect. I have to unplug the modem and sometimes it will still...
Does it feel hot to the touch? Is it dusty? Do you have it sitting where it can get air circulation around it? If it is getting air and isn't dusty the unit might be getting glitchy. They can do that before they go out sometimes. It may need to be replaced. However you may also have a problem with the connection itself on the other end (the provider's end). If you don't have a static ip address most ISP's will assign a different ip address if/when the modem is rebooted sometimes, but they can also keep the same ip address for a long time dispite rebooting. (when you unplug and start it again it is rebooting). You might want to check with your provider and see if they can change it to see if that helps. Sometimes it's their end that is glitchy...
Jun 25, 2011 | Arris High Speed DSL Modem
Gross leak evap code
your evap vent solenoid needs replaced this part is located by the evap canister under the car.
Jul 27, 2009 | 2001 Hyundai Sonata
The internet red light comes on on the d link modem regularly- sometimes for hours, rebooting does nothing often- it was supplied by aol DSL 2640R- I have had it for about six months and gradually the...
hi der... usually this kinda issue most of the time lies with the service provider.. but also to play safe...if can u may try to get another modem to test the connection. well internet light turns red . possible reason :
DSL keeps disconnecting - Frequent intermittent causes ur user id and password to be erased and therefore u need to reboot or may need to configure back
2nd : u may sometimes face night dc , if tats the case its the ISP circuit problem.. ask them to come and change the circuit which gives u intrnet access.
3rd : ur modem unable to save ur configuration ... therefore ur modem mite be at fault
or u can contact the respective modem vendor to check if ur modem is at fault before calling ur isp .. this mite help u pal...
TC...
Jul 07, 2009 | D-Link Computers & Internet
We have actiontec verizon router/modem GT704WG. We have to reboot our computer and router multiple times a day to get the internet to work. It will be working, then all of the sudden it just stops, and we...
I have had this same problem with Qwest using a new iMac and MacBook on the Actiontec modem. Qwest did two things: first we reset the modem which was fairly simple and took only about 5 minutes. However, this fix lasts only a few weeks and it comes back. I have just ordered a new modem since there seems to be a problem with the Actiontec device with the newer high speed internet.
I'd try the reset before doing anything else. Good luck.
Jun 25, 2009 | Actiontec GT704WG Wireless Router...
Loosing internet
Call Verizon and have them check the phone line. it sounds like a problem only they can fix.
May 30, 2009 | Actiontec (GT701) Modem
Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
Apr 03, 2008 | Agere (DSLU56KPCI) Modem
NetGear DM111P ADSL2 DSL Modem Logo
89 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
