Have siemens washing machine with cold supply in now running the whole cycle on cold is it the thermostat or the element
  • Washing Mach... Master
  • 17,129 Answers
You must check the continuity of the element , check the wiring to the thermostat and the control panel.
Click on: Element
Posted on Jan 24, 2013
  • 185 Answers
SOURCE: getting error code e:02 on
model number please
Posted on Mar 28, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
  • 190 Answers
SOURCE: SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Posted on Apr 09, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Water continues to run into
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Posted on Dec 17, 2010
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Changed the element in my bosch washing machine and still trips the electric ,can i wash on a cold wash without tripping the electric.
In the washing machine your hot water supply comes from your water heater. The element that is tripping is part of your electrical so no you cannot expect a different result. You will have to fix the problem first before you wash.
Feb 19, 2015 | Bosch Washing Machines
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
Cold Fill Siemens Does Not Get Hot
yes this could be the heating element or thermostat
May 29, 2013 | Amana ALW880WH Top Load Washer
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
Hotpoint aquarius washing machine never gets hot water
Possible that the HOT line is not working, check the hot water inlet line, Check the voltage to the heating element, check the element.
check the wiring.
Click on : Element
Jan 23, 2013 | Washing Machines
The soap powder in my washing machine is not getting dissolved. This is a front load A07-16 electronic model.
This will be due to one of three causes.
  1. You are using an incompatible wash powder for your machine. If you're in India (the WM A 0716 was an India-only model) then some of the cheapest domestic brands are really poor quality and some of the established major brands are counterfeit products.
  2. Most powders contain some insoluble components which should be rinsed out, so the rinse cycles are not working correctly. This can happen if the wash load is too big for the machine and fails to allow space for the rinse water to circulate, otherwise it's likely a machine fault.
  3. The wash cycle is too cold. You have either selected too low a temperature or the machine has a failed heating element.
If the machine is faulty then you will need to contact Siemens for repair.
Sep 17, 2010 | Siemens Washing Machines
I have a siemens waching machine model no wd11640hkbu. few days back when we were running a wash + dry cycle, while it was on the last 5 minutes of the dry cycle, there were loud banging noises and some...
Front laod washers have a heater element The siemens is mounted at the front of the drum Most likely the heater is burnt out and will need to be replaced. not a difficult problem. The heater has probably burnt itself into an open circuit situation and so the machine now still works. it may not work right through a cycle if temperature is selected other than cold.
You should not have to repalce the machine for the sake of a heater if tis is the case. Why not call knowlegable technician to ascertain this problem. For someone to assume the motor is burnt without looking is not thorough. The banging noise may have been the drum hitting against the burnt out heater element. Good luck
Aug 01, 2010 | Washing Machines
Hi everybody, I have a SpeedQueen Washing machine that does not complete the whole cycle while washing, it stops at the mid-cycle. What could be the cause? Thanks
It could be the heater element, if the wash water does not reach the temp selected by you within a certain time period, the w/m could abort the cycle.
The pump or outlet hoses could be blocked and the w/m cannot expel the waste water between rinses.( This would be if the machine stops and is still full of water). Try running a cold wash cycle and this should confirm if it is the element as it will complete the cycle ok.
Hope this help
Jul 08, 2010 | Washing Machines
Blowing cold does it need a element or thermostat
an element will run you from a re-string @ $30.00 to a box element up to $65.00,plus labor, any other parts will be from $10.00 to $25.00 plus labor
Oct 23, 2009 | Indesit WA 125 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
