Question about Whirlpool Washing Machines
Washer is shaking to much on rinse cycle
Has three springs attached to the basket all are good ,spring on the back frame is good It has a brown plastic piece over each leg -gliders maybe- they are all intact and look good then it has 3 white plastic pieces under the basket all those are good. Hadnt been moved just started shaking bad like there is a weight out of place but isnt any weights on it. Checked the back self leveling legs they are free and move up and down. Possible something In the Transmission?? Thought it either worked or it didnt? Need Help Please if anyone has any ideas
  • Whirlpool Master
  • 17,129 Answers
Possible that the bearings are tight, check for free movement, Check the leveling of the machine. Also try with lighter loads to confirm if the counter weights are acting properly.
Click this link: Bearings
Posted on Jan 24, 2013
Coldcut
  • 1554 Answers
SOURCE: washing machine on laminate flooring
Drill small plug holes to let the washer set on the concrete
Posted on Feb 13, 2008
SOURCE: kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
Posted on May 04, 2009
  • 138 Answers
SOURCE: can not keep the HE 3 washer from jumping around
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Posted on Sep 24, 2009
  • 132 Answers
SOURCE: The washer clunks during spin cycle.
If the inner basket has broken off on one of the three braces on the back side where it is welded to the main spindle shaft that goes through the outer shell and bearing, you will need to replace the spindle and probably the inner basket. Some come together, some can be bought seperately and bolted. Not sure which yours is. Most people go out and replace unit rather than attempt ths repair because of cost if done by a appliance business. It is a complete tear down, and part or parts are expensive.
If you grab the inner basket and try to move it side to side, it should be solid.. The whole tub assembly can move while your doing this, but the inner basket should be solid in the back bearing
Just one idea..
Posted on Jan 13, 2010
Testimonial: "The inner basket seems firm inside the outer drum. Can't figure out what caused the outer drum to have pieces break off. Thanks."
blueextc3221
  • 15935 Answers
SOURCE: when stackable washer is in spin cycle it bangs on
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Why does the washer basket tilt to the side
Had a similar problem, this might be the solution.
Unplug the washer, remove the two screws that hold the control panel to the top. Tilt the panel back, remove the plug going to the top and the two clips that secure the back to the case. Tip the case forward to release it from the front edge of the bottom frame and set it aside. From the front, you should see two springs attaching the bottom of the tub to the lower frame. The tub end of the spring is attached to a bracket that is screwed into the tub. In my case, the screw holding the bracket to the tub had vibrated loose, causing the centering effect to be lost. There is a third spring in the back if those two are intact.
Replace the bracket and screw, and you should be back in business. Best of all, it only takes time.
Feb 13, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
Tub gets easily out of balance when washing towels or jeans.It pounds enough it walks across the floor
there are three or four balancing springs under the drum attached to the frame and drum carriage chances are that one of these springs has broken or come undone they only realy do alot during the spin cycle if you are ambitious turn off the water and unplug the washer pull the back off and have a look see underneath if you do find a broken spring with a pair of pliers bend a new loop in the spring and hook it back up Good Luck
Oct 13, 2009 | Washing Machines
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
After replacing the motor coupling my machine wobbles like crazy
There is a skid plate between the basket support and the A frame. If that is not positioned correctly it will shake. Also make sure the machine has leveled out by tipping forward and allowing the self leveling legs to operate(making sure they move freely)
Eric
Jun 25, 2009 | Kenmore 24032\24036 Top Load Washer
I have an atlantis serial # 16100596av the washer shakes and vibrates sometimes excessively on the rinse as well as the spin cycle. i hope this is an aesy solution!!
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Apr 12, 2009 | Washing Machines
"whole new machine" per technician-STILL shakes uncontrollably
I had the same problem. I fixed it but not sure how long it will last. There are two load balancing springs one on either side of the drum. In my case one of them was apparently assembled without the plastic bushing where it attaches to the frame of the washer. This caused the spring to wear a slot all the way through the sheet metal and fall off. This left one spring attached pulling the drum to one side causing an unbalanced load. I ordered a new plastic bushing and spring online for about $40 for both. I then used JB Weld to fill in the gap where the sheet metal was worn through then reassembled with new parts. Been fine now for about 6 months.
Mar 24, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore Model 80 110-9258311 Spin balance issue
On the bottom of the basket there are springs. These springs keep the basket from slamming all over the place when in spin and agitating. Check that these springs haven't fallen off or come loose. I am guessing that this is all that happened. During moves this just happens sometimes and it's easy to fix. Hopefully you didn't loose any springs along the way, but if you did just call your local appliance repair shop and get some new ones. Kenmore parts are easy to come buy. If the springs look good check and see that they aren't real easy to expand. They should be real stiff. If they are easy to expand replace them. Let me know if you have any other questions and let me know if this was helpful. Good luck.
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
