Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
I'd make sure that you have configured the correct wireless security type. If your tablet allows both WPA and WPA2, make sure whatever you selected matches the configuration on your WiFi router. Also, the encryption algorithm has to match - AES is the most common but some older routers only support TKIP.
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
