Question about GE Spacemaker JVM1640SJ Microwave Oven
My jvm1740dm1ww continually beeps and message "Control Panel Service Needed" appears. What does this mean?
The display on Microwave stated " Control Panel " needs servicing? Is this something minor and can I repair it myself? Please advise. Thank You- Frank
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
You need a new control panel.
Posted on Sep 23, 2014
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: GE Spacemaker Xl 1800, model JVM1860BD001
The parts need to be replaced by an authorized repair service!
FIXD???????????????NOT FIXED
Posted on Sep 02, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave is beeping with F3
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 09, 2008
sonicboomele
  • 1557 Answers
SOURCE: My GE microwave JVM1740DM1WW no
there is no easy fix to this units current problem it will need to be looked at by a service tech as the fault is an internal circuit shortout and needs to have the faulty circuit found and then replaced using expensive testing units
sorry
merry christmas
Posted on Dec 22, 2010
  • 65 Answers
SOURCE: my GE microwave (model# JNM1541DN1BB)
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Posted on Oct 01, 2011
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Microwave is beepen
You have a shorted membrane keypad.
Thanks for showing the full model number.
For model JVM1740DM1WW / JVM1740DMWW01, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
A video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11041 (same as AP3993899) and you can get it from the Pros here for about $159. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link by entering your model number (JVM1740DM1WW or JVM1740DMWW01).
Nov 28, 2012 | Microwave Ovens
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
F3 flashes/beeps. I see it says its a damaged keypad that needs replacing--"a simple DYI project." I'm willing to give it a try, though I haven't a clue or ANY experience how. I mean not...
HELLO.
THERE IS SOLUTION TO THE PROBLEM.
An F3 error code indicates that the keypad for the control panel is bad. This will cause the microwave to beep continuously after the set clock message appears.
Need things
* Phillips-head screwdriver
* Hair dryer
* Key panel
* Key membrane
1 Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
2 Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
3 Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
4 Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
5 Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
6 Repeat Step 5 for the other membrane that is on the control board.
7 Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
8 Peel the wax backing off of the top membrane, then place it on the control board.
9 Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
10 Plug the microwave back into the power outlet and reset the clock.
Willing to help on other problems.
Thanks.
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
F3 code
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
My GE microwave JVM1740DM1WW no longer is responsive to the keypad. Lights, fan, power etc. don't turn on. Just beeps and gives a "disply shortage" error message along with a "might need...
sorry
merry christmas
Dec 21, 2010 | GE Profile Spacemaker Over-the-Range...
I continue to get a message on the little screen that says "F-4" Then it continually beeps day and night! The only way I can stop it is to start the microwave cooking, then open the door to pause...
F4 means Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds it says to replace the sensor.
This is how sensor looks like :-
http://www.repairclinic.com/PartDetail/Sensor-or-Thermistor/253789
Once replaced, it would fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave beeping and says keypad short may need service
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Jul 26, 2010 | GE JVM1850 1000 Watts Microwave Oven
William E. Miller
prototech@usa.net
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
57 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
