Question about Hunter 52" Ceiling Fan With Light And Remote Control
Light will not work
Light worked at first and now will not work
    Genius:
  • Hunter Master
  • 1,617 Answers
Need more info about fan . Make/model? Did it come with light or is it an add on? How do you operate the fan/light? Remote,pull chain or wall controll.
Posted on Jan 24, 2013
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Turn signal not working
TAIL LIGHT NOT WORKING
It can be faulty tail light bulb or its issue with tail light control switch or its wiring's are short.
Check the voltage at fuse slot of tail light.Do you receive 12 volt there.If not,then it says tail light switch is not receiving power supply.
There are few help links related to your problem.I suggest you refer the list and check the help links.Click the link below:-----
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR 4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
1994 Toyota Camry: Bypass Tail light Relay Circuit?
http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2008 Toyota RAV4: Replace Tail light Lens Cover?
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
These details will help.
Thanks.
Feb 15, 2013 | 2004 Pontiac Grand Am
Tail light and the tag light will not work
Sounds like a problem in the wiring harness.
Jan 10, 2013 | 2002 Chevrolet TrailBlazer
I have no break lights or turn signals
Turn signal tail lights and BRAKE LIGHTS NOT WORKING
It can be faulty brake light switch causing the problem or its blown brake light bulb. First check and confirm brake light lamp is working and that's not the case.
For turn signal not working it can be faulty turn signal switch or its issue with wiring:----
To trouble shoot brake and turn signal related problem, check the help links mentioned below:-----
Click the link:----
1996 Buick Regal Grand Sport Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work, but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
2003 Chevrolet S10 Tail light Fuse http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Turn Signal Not working http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Turn signals not working on 1987 Jeep Wagoneer? http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
1996 Chrysler LHS brake light circuit wiring diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake lights on 2004 Toyota RAV4? http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html 2007 KIA Rio: Brake Light Fuse Box Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
2004 Ford Mustang: Brake light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These will help.
Thanks.
Nov 24, 2012 | Cars & Trucks
The tail lights do not work. The headlights, blinkers, and brake lights work. I checked the fuses and they are all good.
1994 Toyota Camry: Bypass Tail light Relay Circuit? http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
--------- Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
---------- Car Tail Lights Not Working?
---------- Right turn signal not working on Pontiac Car?
Thesedetails will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
I have a jeep grand cherokee 2001, my tail light on the drivers side dosen't work, i replaced the tail light assembly, and it worked for a couple of weeks, now it's not working again, the turn signal,...
Tail light and backuo light are separate circuits. Backup light is under the control of the backup switch located on the shift lever or transmission. Thats why one might work right and not other. Most troubles of this type are due to poor ground connections Check again what you did to change the tail light assembly
Jan 05, 2018 | 2001 Jeep Grand Cherokee
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Back tail light wont work fuse is not blown, my revers light work, and my brake light, but my running brake light isnt
tail light will not work when i turn my lights on in my vauxhall cavaleirbut my fog light works when i tun it on
on my passenger side
Jul 20, 2008 | Mitsubishi Galant Cars & Trucks
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
