Fault F05 flashing
Machine won't pump out water on any programme - clothes stuck inside!
  • Washing Mach... Master
  • 17,130 Answers
First of all remove the hose and drain off water then open the door . Once the drain pump outlet filters and the inlet filters are checked, check for free flow. If the cycle does not start check for power output from the controller on pump and motor. If not the board is a suspect.
Posted on Jan 24, 2013
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Posted on Nov 23, 2008
barkencoa
  • 3463 Answers
SOURCE: I have a F05 fault code on a Hoptoint AQxxf149. Washing machine
The pressure switch is located in the top of the washer. To locate it, look for a small diameter plastic or rubber tube about 5mm in diameter.This is connected to the preesure switch.
Please rate my solution.
Thanks.
Posted on Apr 16, 2009
dh1200s
  • 335 Answers
SOURCE: Model FAV6800AWW will not pump water out if clothes are in machin
Hello domino14
Your experiencing symptoms of clutch malfunction with the FAV6800AW. Do you want to dive in and try to fix? Here is what is involved to pull the clutch out of your machine. Also read the last couple of post in this forum. If you call a repair service in your are looking at $300 +. If you can DIY the repair cost could be from $10 dollars if you just need a roller clutch clean up and re-lube to $50 -140 for a replacement clutch. I’m cheap and would go for the $50 Clutch.
First check is to lift lid and see if you can rotate the empty wash basket CCW with one finger. That will let us know if you are experiencing some drag with the roller clutches in the clutch assembly. Here is a step by step to remove the clutch. It is a tight work area but can be done with basic hand tools and basic mechanical skill sets.
What is the serial number of your machine? Just need the first two digits i.e. 10, 12, 14, 16. This info is located on the top right back side of the console.
Next comment will be the clutch removal process, this board has message limits.
Posted on Apr 24, 2009
SOURCE: F05 Fault code
this will be the motor brushes
Posted on Jul 29, 2009
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Hotpoint wt640g washing machine with F05 fault. I have read and tried other customers fault finding answers but to no avail. I have taken all the pipes off and checked for blockages (none found) checked...
Hi
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wmd960. I left it on a wash this morning & came back to lights flashing at the bottom of the screen & I think it said f05 but not sure. I have got a machine full of water,tried to...
Sound like the pump is jammed /also you may need to clean filter its located bottom of drum sump hose lies within this hose big white nylon secures it onto the drum......
Jan 02, 2011 | Washing Machines
Hi, my ultima machine door wont open and says error code f-05, can you help.
Link to the service website: http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
From the owner's manual under troubleshooting:
Error code: F05 - Pressure switch jammed on full
The door will not open...
● Has the programme finished? Is ‘End’ lit
in the display window and the ‘Keyhole
symbol deactivated?
The door will not open until the ‘Keyhole
symbol goes out shortly after the
programme has finished.
● There is still water in the machine.
Go through all the points in the next
section,‘The machine will not pump out
water...’
The machine will not pump out the
water...
● Make sure that there is no blockage in
the drain hose and that it is not kinked.
● Is the drain hose installed correctly?
● If you have connected your machine to a
sink waste system, make sure that you
have cut out the membrane from the
under sink drainage system.
(see section: INSTALLING YOUR
MACHINE).
● Ensure that the drainage system,
standpipe or under sink connection is
free from any blockage.
- If any of the above are found to be
the cause of your problem you will need
to run the machine through a spin only
programme.
● If you have chosen ‘Rinse Hold’, the light
will flash until you press the ‘Rinse Hold’
button to continue the programme.
Jan 16, 2010 | Hotpoint Ultima WF865 Front Load Washer
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Hi.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
