Question about Konica Minolta bizhub C351 All-In-One Laser Printer
How do i reset the replace imaging unit on the konica minolta bizhub c351
  • Konica Minolta Expert
  • 337 Answers
Replace the image unit or replace the iu chip
Posted on Jan 30, 2013
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
  • 44 Answers
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
Posted on Nov 29, 2009
xeerie
  • 347 Answers
SOURCE: i have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
Posted on Jun 18, 2010
xeerie
  • 347 Answers
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
xeerie
  • 347 Answers
SOURCE: I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
Posted on Jun 21, 2010
Black streaks
could be a bad black image unit, xfer belt or fuser
Jan 15, 2014 | Konica Minolta bizhub C351 All-In-One...
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
Where do i find the imaging unit on the konica minolta bizhub c351
They are under the toners. I think you use the t handle tool to remove them. be careful of the toner port flap. they break easily.
Jan 23, 2013 | Konica Minolta bizhub C351 All-In-One...
How to reset image unit for C350 bizhub?
well there is a chip on the image unit that image unit (all colors) you need special chip writer to reset. you may need to just buy a new unit or drop me a line i may be able to get one...
Oct 27, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
Error 2652
C2652 Magenta Imaging Unit EEPROM access erro. you need to:
1. check if EErpom of Magenta Unit is not dirty. if it is, clean it.
Else, replace the Unit image.
Aug 08, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
128 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
