Question about Linksys Wireless-G WRT54GS Router (e125894)
Can not connect without resetting router each time from base
Using wireless G , I can not connect with the internet without first resetting the router. I am within 20 feet of the base and have the wireless G plugged into a 2.0 USB... Can you help me thanks
  • Anonymous Jan 30, 2009
    How do I run the firmware once I download it ?
  • 68 Answers
Try and update the wireless G's firmware....
it should solve your problem....
Posted on Jan 28, 2009
I have to reset (unplug power, wait 10 secs, then plug back in) a lot to have internet access. The router is recognized and it says that I am connected, however it also says that I have no internet...
There are lots of factor why you have that kind of problem when it comes to your router. Before following the steps in this, check if your computer has a stable Internet connection when connected directly to your broadband modem. If you do not have a stable Internet connection with your modem, kindly contact your Internet Service Provider (ISP).
May I know what is the model and version of your Linksys router?
If you run into Intermittent Wired Connections Using a Router:
Step1: Enabling MTU on the Router
- Access the router's web-based setup page.
- Open a web browser such as Internet Explorer.
- Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
- A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
- NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
Step2: When the router's web-based setup page appears, look for MTU and set it to Manual. Enter the MTU value of your Internet connection in the Size field.
1468. The size DHCP or cable providers prefer.
1400. Maximum size for DSL.
Step3: Save settings.
If you run into Intermittent Wireless Connections Using a Router:
Check if your wireless computers have stable connection when connected to other wireless networks.
Regular wireless disconnection can be caused by different factors such as:
> Wireless interference within the network.
> Wireless settings of the Linksys router are still set to default.
> Firmware is corrupted.
NOTE: If the procedure does not work, needs to update the router
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
WGR614 v6 Fails to connect to internet, no wirelss signal
mabey there is a problem with the LAN cable or a connection error
Dec 12, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Wireless router not working all of the sudden
Reset your router, it would enable you to connect
On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Dec 12, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Netgear 824, security = intermittent WiFi connectivity
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Jul 13, 2009 | NetGear RangeMax WPN824 Router
Netgear does not have wireless signal
5. Power cycle.
Apr 09, 2009 | NetGear RangeMax WPN824 Wireless Router...
Missing password and printer connection
are you using internet router for your wireless network? you download software for your internet router or if you want reset your internet router this will refresh your router and give the manufacturer original settings with "admin" user without password.
you can also connect your printer to other computer and share it so that other computer on your network cab use it. just open the share printer in the network and windows will install it or go to add printer and look your printer using network.
hope this will help you.
Nov 24, 2008 | Linksys Ultra RangePlus Wireless Routr...
Internet Connection
You know it is not your connection nor is it your modem. Contact your isp and ask them to release and renew your ip lease. Then connect the router and retry. Should be good. Otherwise contact Microsoft
(800)936-3900,
choose 1 from the confusing menu. The line is free, open 24/7 and there is no
waiting. The best part is that they are very knowledgeable and helpful
Jan 09, 2008 | Microsoft Broadband Networking MN-500...
Zoom X6 wireless router
Hi, With or without the firmware update, the wireless should work and be indicated with the WLAN led. Have you done an update? Have you tried a hard reset? Most routers would require a reset to default after a firmware update. Pls be reminded that when you do a hard reset, all configuration would be lost, better log them down or do a backup. Alternately, you can check your router's web based configuration manager, apparently, there is an enable/disable feature/selection for the WLAN. Verify that is set to enable. Hope this be of help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
Oct 02, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
