Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
My richman hot water heater quit working today, we got our lp tank filled yesterday. did that have something to do with it?
Serial # RMLPO50613464. model# 5VRP40-P
Our tankless hot water heater runs cold sometimes.
Check for crossover: Where bad faucet cartridge or check valve lets cold enter hot pipe so hot never arrives at tap.
http://waterheatertimer.org/Crossover.html
If problem is not plumbing, then add a comment and describe which water heater you have, including approx age and what has been done so far.
Call local plumber to fix tank-type heater
If you have tankless, call manufacturer to get list of local technicians who work on these computers that heat water, or save money and tear it off wall and install tank-type heater today.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 04, 2013 | Bosch & Tankless LP Hot Water Heater
Water heater not making hot water
1) Electric water heater can be repaired, no need for new one.
Copy following links:
http://waterheatertimer.org/images/Water-heater-ther-ele-600.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
2) Ordinary homeowner can turn 6-year electric tank into a lifetime tank.
http://waterheatertimer.org/How-to-maintain-water-heater.html
3) If you replace heater, then buy inexpensive tank-type from local box store, and use coupon or offer 10% off. Read the product manual.
Avoid tankless at all costs unless you are rich.
No need to buy expensive water heater on the promise of thicker insulation or higher energy factor, or 'lifetime elements' or 'advanced technology', any other slicker promotion aimed at folks with the promise of a golden rainbow of money-saving-bliss if only you would spend more money. All costs are energy. Expensive water heaters do not pay back, and 1 repair will dissolve all anticipated savings. And expensive heaters can never be maintained to last as long as ordinary tank-type electric.
Feb 17, 2013 | Reliance Water Heaters
I have hotwater in the tank but none at the faucets.
By-pass may be faulty. Are you getting good pressure on hot side, even though not hot?
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
WHAT SIZE HOLE IN JET ON HOT WATER HEATER TO CHANGE FROM NATURAL GAS TO LP GAS
That doesnt work with these units they are manufactured gas specific. The manifold plate would need to be changed as well as notification to Noritz to have a new serial # issued. PC board reprogram required, etc. Buy a natural gas or LP model.
Apr 27, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Cannot get hot water
Make sure breaker is turned on. If that isn't it tell me model number and maybe I can help you more
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
PowerStar. Model 45-557701 tankless water heater water wont get hot...it slowly quit getting the water hot
Hot Water Hot to Cold And back. I had that problem for 2 years. I had a very large shower head from the time I installed the tank-less hot water heater and the water temp would change from one extreme to another. Over time my shower head had stopped working as well as it did so I bought a smaller shower head and installed it and amazingly my water temperature quit changing temperature. I now turn my water to what temp I want and it stays there. It's been working correctly for 6 months now ... until yesterday and it quit working completely which is the reason I'm on here. lol
Jan 07, 2010 | Bosch & Tankless LP Hot Water Heater
Richman gas lp tankless hot water heater. used for infloor heat and kitchen and bathroom hot water. getting c2 and 11 error code. water temp. setting 120. ran great last year. made no changes. we have very...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 09, 2009 | Rheem Tankless Hot Water Heater...
Water was extra hot yesterday but not even warm today
you might want to look the tempture sense to be replace.
Mar 16, 2009 | Water Heaters
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
101 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
Richard Lindsey ...
ray gallant
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
