Question about Whirlpool Washing Machines
I have a Whirlpool Cabrio Washer Model # WTW5600XW1, When placed on normal wash cycle, washer skips the drain and spin cycles, and no error code flashes?
  • Whirlpool Master
  • 17,129 Answers
If the same fault comes on other programs then it can be due to the controller board.However you can check the drain filter and pump , check inlet water flow to the drum and also check if the water level sensor is working to the set level.
Posted on Jan 24, 2013
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Posted on Sep 30, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
How to fix error message SD on our cabrio washer
Check the drain hose for kinks. Then check entire circuit: tub drain>drain hose filter>drain hose pump> drain hose for blocks. The particulars for your model would be in the owners manual or service maual.
Sep 06, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
238 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
