Question about Maytag MBF 2256 Bottom Freezer Refrigerator
Reset icemaker 12685007
How do you reset Ice Maker 12685007
aborcass
  • 2651 Answers
SOURCE: Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Posted on Feb 24, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MSD24GR ICE MAKER
you need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Posted on Aug 09, 2008
appldoctom
  • 311 Answers
SOURCE: Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Posted on Jan 02, 2009
  • 686 Answers
SOURCE: Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Posted on Feb 26, 2009
  • 66 Answers
SOURCE: icemaker
this is a test, if its a new er model, turn maker switch off for 15 seconds,turn on move the flap arm below the maker bak and forth 3 times waite 3 min, this should reset maker
Posted on May 07, 2010
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
Mar 06, 2017 | Refrigerators
I have to press the reset button to get the ice maker to release the ice.
Hello Christine;
My name is Peter. I am a retired field service refrigeration technician, living in Baltimore, Maryland, USA.
You have not provided a model number so I will address the basics of a ice maker. There are many different kinds.
Not many ice makers have reset buttons. If you have a ice maker with a red reset button in the front you probably have a plastic flex mold. Your ice maker like many others has a control module assembly at the front. This module is actually a computer with a circuit board and a motor. The module tells the ice maker solenoid valve to open and fill the mold with water and what volume of water. Then the temperature sensor tells the control module that the ice cubes are frozen. The module turns on the motor to harvest and flex the mold.
Under your ice maker mold has a white wire beneath it. This is the temperature sensor. Your temperature sensor has failed. This is an solid state part of your ice maker and not replaceable. The ice maker that you have is not repairable. Some ice makers are repairable, but not yours.
When you push the restart button you are forcing your ice maker motor to turn on and harvest the ice cubes.
Normally you should get 8-10 ice cube harvest within a 24 hour period.
Nov 23, 2014 | Refrigerators
I need to thaw the ice that is in my ice maker (Kenmore Elite, 106.56709500), how do I do this? Can I just remove it?
Just get a new ice maker on cheap on ebay since the heating element (for ice removal) on tray will cost more than a new maker!
Aug 25, 2017 | Refrigerators
Ice maker quit working
Try and check the water valve for proper operation.
then check and see if there is a kind of ice blocking the fill tube to the ice maker.
there maybe a reset button on the ice maker that just might reset the unitif nothing else is wrong then you need to replace the ice maker. there might be a cover on the front of the ice maker that you can remove and youmight be able to advance the ice maker manuallyby using a screwdrive to turn the gear clockwise just until it starts to turn on it own and see what happens if you can advance it by hand
Feb 07, 2010 | GALAXY Microsystems 25.4 cu. ft....
The refrigerator icemaker does not make ice.
you have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Jan 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice Maker stopped making ice - water dispenser is fine.
well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Dec 30, 2008 | Maytag MSD2456G Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBF 2256 Bottom Freezer Refrigerator Logo
120 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
