Question about Samsung HCM4215W 42" Rear Projection Television
Check fan # 1
I have a Samsung 46 ich model HLP5063WX
I currently have an error mesage that flashes "check fan #1
Should I assume that fan #1 needs to be replaced?
How do I know which is fan #1 ?
  • Anonymous Feb 10, 2009
    wont swich on
  • 537 Answers
There is a slight possibility that fan #1 is still good. I would still investigate it though. If the heat is not controlled, more damage could be done. I'm not sure which fan is #1. I think on the PCB of the TV would have some kinda of marking that would say FAN 1, FAN 2, etc.
Posted on Jan 28, 2009
Samsung DLP hlp5063wx/xaa - Cycles through the warm up 2 times but does not turn on, then 3 lights flash on the front (2 green, 1 red) Bulb is new and looks good, fans seem to be spinning freely. Any...
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first since you say the fan is spinning. The thing is the lamp will not turn on if there is a problem with one of the other two parts. The motor on the cooling fan is too small for such a big fan so I would definately try it next. It's a big problem with the DLP tvs. good luck!
Feb 14, 2011 | Samsung Televison & Video
I replaced the bulb today and the red lamp still flashes. alsol the tv automatically starts when i plug it in.
Check Lamp Fan and the Ballast board that Lamp connects to.it is what powers Lamp. Encompass Parts 1-800-638-3328
Feb 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning off
Lamp! Or defective Lamp Fan that cools Lamp, Call Encompass Parts or visit them on their website.
1-800-638-3328
Oct 05, 2009 | Samsung HLR6178W 61" HDTV
HLM507W #1 Fan Problem
Yes the set isnt recognizing that after market fan thats why the Fan error is flashing.
Jul 12, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Samsung shuts off automatically
Check air vents around cabinet. Suggests over heating and shutting down due to thermal switch. Clean vents and fan inlet
Jun 27, 2009 | Samsung Televison & Video
Samsung sp50l6hd it is showing up on the sceen fan 2 error can any one help?
If a “Fan error message appears on the screen:
1. Look at the fans to see if they are running while the unit is on. If not running check the connector. If the connector is good replace the fan.
2. If all fans are operating, problem is in the fan detection circuit, Actuator, Protection Board or Digital Board.
May 15, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp5063wx fan
Quite possibly; the set apparently is sensing the operation of the cooling fan and that is probably defective. These sets generate a great deal of heat in specific areas and with no fan, they would quickly fail from heat alone.
You should be able to spot the likely place for the fan if you remove the lower back panel of the set. If is probably a 'commodity' fan that is available from multiple sources; I wouldn't go to Samsung first since they will mark it up a bunch.
If you can gain access to the fan and it isn't just being impeded by an accumulation of dust, get the make and model number of the fan from the label (almost always present) and do a search on the information you find.
Nov 08, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
492 people viewed this question
Henry  Thomas
Henry Thomas
