Question about HP DT PAVILION P6110f DESKTOP PC
Does not power up
Computer is connected to power. Pushing power on button does not power up computer. Is there an internal fuse or circuit interrupter?
  • HP Master
  • 5,660 Answers
No fuse. No circuit breaker.
You either have a bad Power On switch, or a bad Power Supply.
There is an easy test to see which one it is.
Bypass the Power On switch.
Does NOT involve the wires of the Power On switch.
HP Support > Pavilion P6110f Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3970026&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, IPIBL-LB (Benicia),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3970026
Looking at the right side of the motherboard, towards the middle; you will see a white long connector, that has two columns of 12 socket holes.
This is a general example of a 24-pin ATX main power cable, that plugs into that connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Looking at the photo to the far right, you see the power cable plugged into the motherboard. That's how we need it for the test.
See the Green wire? This is the Soft Power On wire. Abbreviated as PS_ON.
A jumper wire is used to Briefly connect that Soft Power On wire, to ANY Black wire. ALL Black wires are Ground wires.
The preferred jumper wire is a straightened out paperclip, bent into a U-shape. Turn the U-shaped paperclip over, and that is how it will be used.
The top of the U is wrapped a few times with black plastic electrical tape. (Or any color)
This taped area is for your fingers, and thumb to hold onto.
The 'legs' of the U go down into the socket holes, of the 24-pin ATX main power cable's connector.
The BACK of the connector is where the wires go in. The Back is where the jumper wire goes in also.
One leg goes down into the socket hole with the Green wire, RIGHT NEXT TO the insulation of the Green wire, and slides down into the socket hole.
It MUST go far enough down in that socket hole, to touch a metal terminal that is on the end of the wire.
Every wire going into that power cable connector, ends in a female Molex connector,
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction
The other leg of the U-shaped jumper wire, goes down into ANY socket hole that has a Black wire in it.
Power Supply plugged into power, the U-shaped jumper wire is BRIEFLY used.
Contact period is no more than 2 seconds.
(The Power On switch is a Momentary Contact Switch)
Shock hazard?
The Soft Power On circuit uses 5 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
Not saying there won't be a spark however, dclipsitt.
You may wish to wear a glove on the jumper wire hand.
Power Supply comes on you have a bad Power On switch.
Power Supply does NOT come on you have a bad Power Supply.
Most of the time with an HP computer, the Green LED on the back of the Power Supply will be blinking, if the Power Supply is bad.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 23, 2013
Testimonial: "I replaced the power supply with a higher capacity unit I picked up at Fry's this morning. Everything is back to normal. Thanks All..."
  • Dave Jan 23, 2013
    Thanks to all for solutions. Will work through them tonight.
    New Friend:
  • 12 Answers
I've never seen or heard of a power supply unit (PSU) that has replaceable fuses or a circuit breaker. Usually, if they are working properly, they automatically reset and start up when any problem circuits are fixed (bad connections, overloaded, overheated, not connected). Usually, if it won't start, it is a bad PSU.
If PSU, CPU, and case fans turn on, the PSU is working. One other thing is required: the POWERGOOD signal in the PSU turns on. When this signal is not on, it keeps the CPU in a constant reset state. It turns on only after all the PSU voltages reach their correct levels. For example, it is possible that the +12v works the fans OK, but if the +3v for the motherboard is out of range, the POWERGOOD signal will not go on.
You can try another known good power supply to see if it works. If so, then you need a new PSU. If not, you've got to do full troubleshooting which requires experience.
Circuit protect fuse
It sounds to me like internal fuse on the power board of the TV. It is usualy a glass cilinder with metal caps on both sides, could be found in any electrical shop or even car-part shops because old cars used same fuses some time ago
Aug 04, 2017 | Acer Computers & Internet
Can't find the window fuse for 2003 caddy cts
Check inside trunk under carpet on rear seat back support.
Nov 12, 2016 | Cars & Trucks
No injector pulse on daewoo nubira i change computer box but still no pulse wot must i look for or replace
Check for an injector fuse in the fuse box under hood. Pull off one injector connector and use a testlight to check for a steady power signal on one of the two wires, with key on. Should have power on one wire. If not, pull all injector connectors off and check again-a shorted injector can shut down the injector drive circuit-if power now, reconnect injectors one at a time. If one connection causes power to be lost, that is a shorted injector. Replace it. If still no power and fuse is good, you will need a wiring diagram to check injector drive circuit.
If you have voltage at the injectors with key on, move the test light ground lead to the battery positive post, and put the test light probe on the injector wire that did not light the test light. Now have a helper crank the engine over-you should have a blinking light on this ground circuit. If no light, or light is not blinking, the ground circuit between injector and computer is bad. See? Steady power is available to injector anytime key is on. When the computer internally grounds the injector circuit for a split-second, the injector is energized, causing the pulse.
Mar 22, 2013 | Cars & Trucks
Po1682
Here is the definition for code 1682.
Problem could be with the ignition switch, the harness, or the computer.
P1682 CHEVROLET Description There are 2 ignition voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set
Read more: http://engine-codes.com/p1682_chevrolet.html#ixzz25wBbBqGe
Sep 07, 2012 | 2006 GMC Envoy
Hitachi P50A402 wont turn on
Could be an open internal fuse or power supply failure. Bet the "tech" didn't check either before trying to sell you replacement boards.
Dec 08, 2017 | Hitachi P50A402 50 in. Plasma TV
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Samsung LCD monitor DC voltage
    The internal DC power supply consists of 2 REGULATED power supply circuits, one is 5VDC (about 1A) for logic circuits, another is 12~18vdc (about 3~4A) for the backlight circuits.
    Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG%20&megnev2=943&kategoria=&kat2=all
    It may not be practical to build two external power supply, and you have to know the points where to tap into on the PCB.
    Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
    Post back what you see inside so we can guide you further and it will help out other people in the future also.
    http://en.wikipedia.org/wiki/Capacitor_plague
    http://www.badcaps.net
    Jun 21, 2010 | Computers & Internet
    Plug it in with no input connected,press the
    I suggest you don't.
    There are no user friendly replaceable parts in there.
    There May be an inline fuse in the AC circuit, but it's probably a circuit breaker. (Closest thing to a user friendly part, that you'll find)
    I suggest you take it to a 'Mom & Pop' computer shop, and see if they will check for a blown fuse inside. The small qualified shops like these, have real computer techs, and not 'Geeks are Us'.
    Plus they're cheaper.
    If it isn't something simple like a blown fuse, or bad circuit breaker, it's probably the power board.
    (Usually the front cover comes off, from loosening it on the backside)
    The reasoning for dissuading you from opening the monitor, is that there are Electrolytic Capacitors inside.
    They are designed to hold a charge for weeks, sometimes months.
    Should you touch the terminals making a circuit, or touch the circuit they're in, and complete a circuit, they could release their charge to you!
    This can easily result in a bad shock, or 'Put X's in your eyes'.
    (The Electrocution warning on the outside is For Real!)
    Apr 22, 2009 | Acer AL2223W 22" LCD Monitor
    Power Probe III
    dear Mark,
    the screen shows "CB", not C8. Stands for Circuit Breaker. This means you have overloaded your Power Probe 3 and the internal thermal fuse has blown. You can simply reset it by pushing the button on the right hand side of the Power Probe.
    Regards
    Werner Klaassen
    Coplan Europe
    Feb 27, 2009 | Power Probe 3 Combo Kit with Gold Test...
    Connection not recognized
    I have often had the same problem. Resetting the software enabled me to recover. Press and Hold the Play/Pause (center) button and the Previous Song/Rewind (rear) button•at the same time. I held it for about 5 seconds. Then I released both buttons, then pressed the Play/Pause for about 1-2 seconds, the unit powered up and I was able to connect and charge the unit.
    • If the reset procedure does not work, you may need to restore the internal software.See your .pdf users guide, this will erase your song list.
    Good luck.
    Oct 22, 2008 | Oakley Thump 2 MP3 Player
    HP DT PAVILION P6110f DESKTOP PC  Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
