Question about Freezers
Iceking model ch102 chest freezer red alarm light is on what does it mean?
  • 61 Answers
SOURCE: freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Posted on Oct 20, 2008
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
barkencoa
  • 3463 Answers
SOURCE: red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Posted on Dec 25, 2008
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Alarm light Westpoint Chest Freezer
is it getting cold inside .why would you want MAX temp tho turn to mid point as a startingplace
Nov 22, 2015 | Freezers
Why is my Skandiluxe chest freezer's red light on
Red light usually means the interior temperature is too warm.
Jun 26, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Red light alarm still on after 36 hrs
Can you hear the compressor humming? Did any water get into the electrics while defrosting?
Nov 11, 2013 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Apr 04, 2013 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Freezers Logo
581 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
