Question about Pioneer DV-C503 Multi-disc DVD Player
DVD stuck in player. Now it does not respond to any buttons pushed.
On button went to off and is staying there, open & close does not respond.
3 Suggested Answers
  • 7 Answers
SOURCE: dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Posted on Dec 31, 2007
  • 24 Answers
SOURCE: How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Posted on Jun 05, 2010
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Sep 01, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
Locked dvd tray.
Do not have better news. You can unscrew the player, and see if dust is stuck in the gear that controls the dvd opener, or check the online dvd repair guys. But, really, it is cheaper/less of a hassle to get a new one.
Jul 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Turning on
I second quavuama. I had the same symptoms after my four-year-old "broke" it. He actually figured it out and suggested the fix. He said "Daddy, the little button is stuck..." OK, yeah right, I said. But he pointed to the small auto shut-off button just above the source and setup buttons. When the lid closes the button is pushed down and off goes the picture. Well little four-year-old fingers was fingering the button and it got stuck in the down position. I used a sharp tip to work it back to the "sprung" position. Picture now comes on.
Mar 13, 2008 | Insignia NS-PDVD8 Portable DVD Player
Tray opens / closes on its own and will not play
Your open/close button might be stuck, you can try and unplug it and spray it with silicone lubricant and push it over and over again for a couple of minutes and then turning it back on after about 30minutes so the lubricant dries down first.
If all else fails, have a local appliance technician take a look at it...
Dec 09, 2007 | Hitachi DV-P323U DVD Player
Pioneer DV-C503 Multi-disc DVD Player Logo
525 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
