Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating strips de-energize. The blower fan motor doesn't come on, however the squirrel cage fan spins freely. The heat pump stopped working several years ago, but I just used the emergency heat option for heating solution. The squirrel cage fan motor was replaced about 3-4 years ago.
    Habit-Forming:
    New Friend:
  • 117 Answers
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Posted on Jun 01, 2017
2 Suggested Answers
SOURCE: Amana Heat Pump Emergency Heat will not come on
On the heating element [behind the coil, (the springy thing)], at the top end of the element, there is a little thermistor I think it is called. You will have to remove the fan shroud. With the power off, check for continuity if you have a multimeter. If that is the problem (no continuity), you can pick one up at al local heating supply. Just have it soldered back in and reconnect. If the thermistor 's continuity is okay, remove the main board under the control knobs. I have seen these boards burn in the back where the relays are soldered on. If you're really good with a solder you can try to re-solder it. If not, it's about as cheap to buy a new unit as it is to buy the board. Good luck.
Posted on Feb 17, 2009
Furnace won't stop running
Jump out limit switch blower should stop and inducer should come on then the heating sequences should start from there
Nov 28, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
What does it mean if your central heat and air unit says emergency under the time and date
your emergency heat is on and your outside heat pump most likely is not coming on
Oct 22, 2009 | Amana Heating & Cooling
Blower motor runs but dies out..
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
the problem sounds like 1 or 2 things either you have a bad sequencer for the heat strip or the emergency heat portion was not wired up.
Jan 30, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heat pump works in emergency heat, but not in auxiliary heat
I set the thermostat for 70 degrees. It comes on always in auxillary heat and does not shut off when it reaches 70 degrees. It is a heat pump, I am assuming, it might be the thermostat? But when the air conditioner is on, it turns off when it reaches it's temperature.
Jan 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Dec 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heat strips not heating
Check your sequencers on your elements. If you don't have the equipment, then all you can do is check your filters and ensure they are clean. Also see if you can set the heat pump at a lower temp, you can do this at the defrost board, the therm or sensor. Get (the heat pump) to heat the house more than the electric before you have a tech come and diagnose your problem.
Dec 07, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana Package heat pump wont turn off
i can help with this. call 1-888-855-9987. The problem is on the board.
Aug 12, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
