Question about Indesit W 123 Front Load Washer
I have an indesit 1wb71250, the man on indesit repair said i need a new pump, how do i do i repair that?
    Problem Solver:
  • 6 Answers
Unless the pump is just blocked ( remove blockage ) the pump cannot be repaired only replaced with a new one .
Posted on Jan 23, 2013
Indesit washing machine pumnp burnt out, replaced it but it still won't pump or spin. Does it need a new programmer or can the programmer be fixed?
You're absolutely right. If you look at the wiring diagram on the machine it is clear that the drain pump is powered by triac on PCB (part code C00270972).
I think it is definitely safer and probably cheaper to replace than to repair the PCB.
It is always a good practice to visually inspect PCBs that there are no visible defects such burnt out elements, etc. before replacing. Sometimes the reason for burnout PCB may be on a completely different side.
25580311-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Dado
Mar 16, 2015 | Indesit Washing Machines
My machine has washed a load half way and stopped. The water is still in the machine and I am unable to open the door. What shall I do
Pull out the machine. remove the drain hose from the water outlet pipe and place it low down in a basin on the floor. The water should empty from the drum by gravity. when the water empties you should be able to open the door.
The water pump may be blocked. To check this, unplug the machine, tilt it machine backwards and have someone hold it. Have a look underneath and if you can locate the pump you should be able to rotate the impeller wheel, (probably plastic) freely by hand. if there is any resistance, it is most likely blocked, (small sock, coin etc.). You may need a service man to repair this
Nov 10, 2010 | Indesit W 123 Front Load Washer
Bearings gone
All Indesit washing machines are aimed at the budget end of the market; as such the outer drum assembly is polypropylene instead of steel. This type of construction is common to almost all cheaper brands which are really designed to simply be thrown away when major parts fail.
Bearing replacement is often impossible as the outer drum inevitably cracks when the old bearing is driven out or when the new one is installed. Indesit do not normally even offer the bearing as a spare part, but if you do get the old one out a replacement can usually be supplied by a bearing shop if you take the old one along for comparison. If you then buy a new bearing and then crack the outer drum whilst trying to install it you won't be able to get a refund.
Your only realistic options are as follows:-
1. replace the entire drum assembly;
2. replace the outer drum complete with the bearing;
3. replace the entire machine.
The first option is not usually cost effective, the second option isn't always possible as it's not always available as a spare part (you didn't state which exact model you have).
The third option may be your only practical solution if you cannot put up with the noise or if the faulty bearing is causing other issues. You also need to consider that if your Indesit is used every day, then it will typically last only around three years from new before major parts start to wear out, so you might repair your machine only to find that it soon needs a new pump or has a sensor, switch or circuit board failure. Better quality (but more expensive) brands will typically last in excess of six years.
Avoid any used washing machines unless you get them for free and they just need a cheap fix like a new pump (or even better when they just need that errant sock pulled out of the tube leading to the pump: many perfectly good machines are thrown away with simple fixes like those). A bargain used machine is only a bargain if it lasts at least a year or two, and professionally "refurbished" machines normally only come with a less than reassuring ninety day warranty.
Mar 01, 2010 | Indesit Washing Machines
Washing machine has broken down
try to put your washer on a drain and see you can hear the pump workng. you should hear a buzzing.if you dont it mite be your pump that as gone. to get the water out pull whasher out near your back door if poss and lie the drain pipe flat the waser will then empty. if there is a buz then you could have a blockage. but if not a pump is no more then 25 pound and are not that had to do
Jun 24, 2009 | Indesit W 123 Front Load Washer
INDESIT W 123UK
belt will have stretched.check motor not loose,make shure large pully tight.
Oct 06, 2008 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Dish washer IDL 550
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher dose not drain water, and now dose not turn on the machin
Any body can help you?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man. If the d/w dosen't come on at all then it may be time to consider replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Indesit draining problem
Yes, it ought to be fixed on. Best plan is to take the motor off the back of the pump body, then do a web search on "Askoll Pump". Compare the one with the pictures on the other. Askoll pump motors are fitted to most UK machines these days, are easy to buy and fit, and a good deal cheaper than replacing the entire pump. If the motor doesn't look like an Askoll, a complete Indesit replacement Pump is a little under £30 on the net, so all is still not lost. A.
Mar 10, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
54 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
