Question about Volkswagen Vw Beetle 2000 Stereo Radio Install Mount Dash Kit
Oil leaking out of front of motor above oil filter
Where could it be coming from?
    Problem Solver:
  • 8 Answers
Check the valve cover gaskets, this is a very common problem over a period of time, and they are very simple to replace.I hope this little piece of imformation will help you. Your Friend davant1958@yahoo.com
Posted on Jan 24, 2013
I have a small oil leak near the oil filter. The leak is not from the filter. Help
is it from oil filter bracket or coming down from above around top of engine front of engine need more information lot of oil does it leak under pressure leaks all the time and where the leak is near oil filter
Aug 26, 2015 | Avalanche 2005 05
Oil leaking heavy just above oil filter ,passenger side 2002 crv ,not coming from head oil leaking heavy passenger side above oil filter, not coming from head
If it is leaking at the oil filter the previous rubber gasket may have stuck to the block. When the new oil filter was installed then the gasket was doubled and will leak.
Jan 04, 2015 | Honda Cars & Trucks
Two very likely causes:
1) Leaking oil pressure sending unit.
This small round unit is screwed in to the block and has a wire or two attached to it.
2) Leaking valve cover gasket. Oil runs down the side of the block.
Be blessed.
Jan 23, 2013 | Cars & Trucks
My achieva is leaking oil at the front of the engine. i cant see exactly but its above the oil filter some where. Where is it coming from and how do i fix it
It could be coming from the oil filter itself. Sometimes when changing the filter, people can overlook the fact that the gasket from the old filter may have stayed on the engine block. Then when the new one is installed the gaskets double up and it doesn't allow the filter to seal. Causing the leak.
Jul 01, 2011 | 1994 Oldsmobile Achieva Special Edition
Has a bad oil leak coming from under the car . The only time it leaks is when the car is running, was told that it could be the oil pan gasket or the oil sending unit, what I wanted to know is where the...
The oil pressure sending unit screws into the engine block so you will need to look between the oil pan and the head.I suggest that you try tightening your oil filter first.
Dec 21, 2009 | 2001 Ford Focus
Bad oil leak driver side front fender
There is an adapter for the oil filter with 2 lines coming out of it above the drive shaft from the transfer case to the front differential. The O ring on these will go sometimes causing loss of oil. Also check the 2 lines for leaks and cracks.
Jul 07, 2009 | 1999 GMC Jimmy
Oil leaking in front of my engine above the oil filter. '92 mercury topaz GS, 2.3 4 cyl
possibly the oil pressure sending unit- looks like a small spark plug screwed into the engine with one wire going to it
May 30, 2009 | 1992 Mercury Topaz
Oil leak
There's not much over there that can leak except for the filter. That diesel oil is heavy and persistent too. It'll drip from those steering linkages forever after a filter change. Check your turbo fittings too. It gets oil and then sends it back to the motor.
Apr 16, 2009 | 1999 Dodge Ram 2500 4WD
Oil leak
there is a gasket between the filter and where it meets the motor. often when the oil filter is overtightened when it is installed it will leak.
Mar 14, 2009 | 1993 Ford Thunderbird
Oil leaking from some sort of plug above the oil filter
If the leak is coming directly from above the oil filter it is more than likely the oil pressure switch is leaking. The seal around the Oil pressure switch could have gone bad and now it is leaking.
The oil pressure switch is located right above the the oil filter and above the cooling system cross pipe.
Dec 13, 2008 | 1993 Honda Accord
Volkswagen Vw Beetle 2000 Stereo Radio Install Mount Dash Kit Logo
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
David Payne
David Payne
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
