Question about Canon PIXMA MP180 All-In-One InkJet Printer
My Canon MP180 printer/scanner/copier is notifying me that the ink absorber is almost full. What is an ink absorber and what should I do to replace it? I live in southern CA.
    President:
  • 787 Answers
Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Oct 21, 2009
Error 5B00
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Canon mp180 ink absorber full
This mayclear the ink absorber problem.There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
May 31, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Error 5b00 how do i fix it
You will have to give the machine to a canon agent as the main ink absorber if full. the machine has to be taken apart for new absorbers to be fitted. It a very messy job and will take a canon trained engineer about an hour to disassemble it. Also the platen ink absorber should be changed too. then finally the software ink absorbers counters will need resetting.
Aug 28, 2011 | Canon PIXMA MP180 All-In-One InkJet...
We have a Canon Pixma MP280 printer and are getting an error message 6. How do we correct this.Please advise. Thanks!
r u sure that is e6?
There are bunch of error code for canon.
Pls check below and re-list your exact error code and can help you.
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
Apr 26, 2011 | Canon PIXMA MP180 All-In-One InkJet...
Where can I buy a ink absorber for Canon PIXMO MP180/MP160?
Access eBay: http://www.ebay.com
Search for 'Canon Pixma Ink Absorber', and you'll find several online sellers -- some with _huge_ shipping-charges ($35 !!!).
Or, find the nearest Canon office, and have them order one for you.
They will pay the shipping, if you pick it up from their office.
Aug 05, 2010 | Canon PIXMA MP180 All-In-One InkJet...
FULL INK ABSOBER
There is no repair for this model, you can't get the ink absorber and if you could there is no reset. This model was exchanged during warranty and after that you toss it and buy a new one. Canon has no parts or service for this model.
Feb 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
My Canon MP180 printer/scanner/copier is notifying me that the ink absorber is almost full. What is an ink absorber and what should I do to replace it? I live in Ireland. Err 5B00
The ink absorber is a small tank that holds the waste ink your printer generates when it cleans its nozzles. Eventually that bottle will fill with ink and if not replaced will result in a terrible, sticky mess all inside your printer and the desk on which it sits.
I suggest contacting a local authorized repair facility for Canon or Customer Service for Canon and see if you can purchase a new absorber bottle without having to take the printer into the shop.
Jan 07, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Ink absorber full
You need a new pad and you need to reset your code.
Codes are dependent on your model.
You can get more info here:
http://www.fixyourownprinter.com/forums/inkjet/32258
Dec 16, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Waste tank absorber is almost full ~ message
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used
during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1
on the display on your camera.
However, because printing is disabled once
the ink absorber becomes completely full
and until the ink absorber is replaced, you
are recommended to contact a Canon
service representative as early as possible.
*1 To resume printing, you can press
[OK] (MP180) / [Black] or [Color] (MP160) on
the machine instead of selecting [Continue].
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
279 people viewed this question
old marine
old marine
