Question about Kenmore Washing Machines
How do you open the front panel on kenmore washer combo model 11098752790
  • Kenmore Master
  • 17,129 Answers
Please check this link for tips: Control Panel
Posted on Jan 24, 2013
  • 91 Answers
SOURCE: Kenmore Model 417.44072300 Front Load Washer Kenmore Model
unless you have alot of money to throw away ,, will run you about 600 to repair washer ,,,not a really good investment ,,
Posted on Jan 04, 2009
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
  • 1937 Answers
SOURCE: Kenmore Washer 80 Series is leaking. Water and
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110-25864400
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on Jan 17, 2010
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
I Have a combo kenmore washer/dryer model # 417.94712400 and I need to open the washer to inspect a water leak. how do I open this washing mashine.
Remove the 2 screws at the base first
If ya run a load with the front off to look for leaks remember there are moving parts
I recently worked on a dryer portion and took these photos
Jul 25, 2011 | Washing Machines
I need to buy the timer for the kenmore 24032 \ 24036
You can buy parts for Kenmore washers from Sears Parts Direct
You need the complete model number You can find it
Front Loader
Top Load
Washer-dryer combo
Jun 22, 2011 | Kenmore 24032\24036 Top Load Washer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer dryer combo " Washer drum leans to one side "
If this is a small combo the problem is probably one or more of the suspension springs has become detached. You need to get the washer cabinet off. take the panel between the washer and dryer off. then there are 2 clamps holding the washer top on. they are in rear right and left. Once you get the top off you will be able to take the front of the washer off. At that point you should be able to see the problem under the tub. In most cases you can reinstall the plastic shaft back into the spring by screwing them back in.. This is not easy but can be done.
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
