Question about HP Pavilion dv6000z Notebook
Connect computer HDMI to Projection TV HDMI to watch web TV
My Panasonic projection TV manual (model PT-47x54J PTV) states on pg. 9 that "the HDMI input terminal is NOT intended to be used with personal computers. This PTV is compatible with 1080i, 480p, 480i formats." The TV is about 4-5 years old but I would like to salvage it for the web if possible as I am cancelling my cable......How do I connect the TV to a computer? Currently have HDMI connection of Pavilion dv9000 but am looking for new PC, as well as LCD HDTV monitor. This would be a backup monitor downstairs...if there is no cable, then the TV is useless unless I can hook it up to a PC. Thanks for your help. ivm.camp@gmail.com
  • 520 Answers
Use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Posted on Jan 29, 2009
Why wont ps3 play out of hdmi port or input connections on Panasonic PT-61LCX65?
becaue you need to enable hdmi on the setting of your TV and perhaps you also need to adjust to the same HDMI value in both PS3 and TV Menus
Apr 01, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
I am not getting true with the connection with my plasma tv to my computer
So you're not getting connected while VGA-out from computer to HDMI-in on TV while using proper cabling (remember you'll not get sound through VGA)?
Feb 19, 2015 | Panasonic PT-50LC14 50" Rear Projection...
Can I use the Panasonic PT-53X54J as a computer monitor?
U have a HDMI hub on this tv?Yes,than u can used it as a monitor.No HDMI hub,can't used as a computer monitor.
Sep 30, 2010 | Panasonic PT-53X54 53" Rear Projection...
Television shuts down with a clean filter error.
i looked all thru the manual and didnt see afilter anywhere. try checking on the back to see if you can see a door where a filter might be. other than that try reaching panasonic at: 1-888-VIEWPTV or on the web at www.panasonic.com/contactinfo For assistance, please call : 1-888-VIEW PTV(843-9788) or, contact us via the web at: http://www.panasonic.com/contactinfo
Oct 25, 2009 | Panasonic PT-52LCX66 Projection Television
Won't recognize DVI
You need to set your input of the televison to either 4 or 5
Jun 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
HELP! I am looking to replace my Lenticular screen for my Panasonic PT-47X54J.. Panasonic has stated this part is discontinued and can't provide a part number.. What should I do? Can a Lenticular screen by...
Hello,You can try to check ebay, amazon.com, and or any of the other bidding sites.I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
Nov 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
HP Pavilion dv6000z Notebook Logo
526 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
