Question about Maytag Neptune MAH5500B Front Load Washer
The wash cycle has inceased the time to 80 min.
Cycle time used to be 45 min. or close to that now is 80 min set on wrinkle free normal soil max extract. What could be the problem? It still washes fine just takes a long time. How do I decrease the time back to like it was new.
  • Anonymous Mar 24, 2009
    There is no reset under options, and max extract is not selected, nothing but normal cycle is selected and it goes to 70 minutes automatically when it used to go to 55 or so.
Under options push reset this will remove the stain cycle and max extract. Your speed should be back now. If your not using the HE detergent you might want to start using it also. I've read in other posts that regular detergent is too sudsy and interferes with the electronic sensors that determine the wash cycle. I hope this helps.
Posted on Mar 24, 2009
My Maytag 9000 started to smell moldy. I tried cleaning the seal, running vinegar through a wash and drying the whole thing out but nothing works.
First pull out soap dispenser all the way ,clean it and inside the hole with mold and mildew cleaner let it soak. Use washer magic on door seal rubber Glover and a rag get in all the creases let it soak at least 15 min. Than that a cleaner called affresh. Taplets. Use two place in tub an run a clean cycle most front loaders have this cycle .if it doesn't max everything hot water extra rinse heavy soil . repeat 1 more time all steps. Than 1x a month pull dispenser clean ,clean door seal and use 1 tablet on clean cycle. Only use 2 table spoons of detergent and only use HE soap
Oct 18, 2015 | Maytag Washing Machines
How do I repair a Cabrio washing machine
Press the cancel button all indicator lights/LED should be off
Select any button except Power, Start,Pause/Cancel
e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
Press "Soil Level" button and hold for 3 seconds
Release "Soil Level" button wait for 3 seconds
Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
Please post the error codes you have noted.
Oct 13, 2014 | Washing Machines
The times seem to have changed on the settings for soil levels. For instance, the quick is 50 minutes and the normal is 84 minutes. That does not seem right. Is there any way to set them different?
Answer to your question "Is there any way to set them different?" Short answer is no. The Maytag Neptune like many other washers that display a time of cycle first start with an estimated time this relays a lot on the last cycle ran. But, more importantly it also takes into consideration other washing options. For example, lets say that your quick wash cycle used to only display 35 min. now if you select an extra rinse option the time will increase from that 35 min. to a higher amount of time. This is due to the longer time it takes to go through a second rinse cycle. The MAH5500 if I'm not mistaken also has a heater in it so there are options such as sanitize which takes 120 degree hot incoming water (suggested temp. for hot water heaters) and heats it to approx. 165 degrees. And as you can imagine this takes a washer some time to do this (increasing wash time). If you would like to lower washing time check the washing options and remove any that are not needed at that time; pay close attention to extra rinse cycles and the soil levels that are selected. Hope this helps. Cheers.
May 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Sep 16, 2009 | Washing Machines
Washer options not working on control panel. The options that aren't working or responding to controls are: presoak, stain cycle, extra rinse, heavy soil, normal soil, light soil. Other options work and am...
when you push the button to select the options that arent working do the lights at the selected option come on? if they do not then you need a new control panel they will cost you approx 100$ to sell it as is you would be lucky to get rid of it, they only last for 7 or eight years max anyway before the outer tub bearing fails.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
I actually don't know what type of Bosch I have. I know that is a problem, but maybe you can still help. It has a simple panel that says: Pot Scrubber, regular wash, quick wash, rinse and hold. When I turn...
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
Jan 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Wash Settings have changed
These times are pre-programmed and not user selectable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2008 | Kenmore 46462 Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Maytag Neptune MAH5500B Front Load Washer Logo
412 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
