Can't find a replacement battery for iubi pmp s30
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
Oct 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My pmp froze, tried to reset it but now it wouldn't power up
Your PMP what? Is this a Behringer?... and if so what model?... If it won't power up, for goodness sakes do NOT replace a blown fuse as additional damage usually results. Get it serviced... if under warranty, then exercise the warranty. If it is a BEhringer, then also read my tip on Fixya tips regarding PMP mixers and a hazard of using 1/4 inch plug speaker cables or adapters.
Sep 19, 2011 | Music
Hi, I have a iubi blue PMP2500(30GB) the problem is that sometimes when I try to transfer files via USB something happens and it freezes,then I can't even put it off as the power button seizes to work...
reset it by sticking a needle in the reset spot then upgrade /update firmware on computer an run check hdd from windows with fix errors option activated
worked for me
Jul 19, 2011 | Digital Blue iUbi Blue Digital Media...
I need a manual for the Sony camera, dsc-s30
Hi there!
Regarding your sony camera dsc-s30 manual you can go to this site
http://www.usersmanualguide.com/sony/cyber-shot_cameras/dsc-s30
and then you can choose which type you would like to download.
or
you can go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCS30
then click OPERATING INSTRUCTIONS. You can now see the manual.
Hope my solution helped you. Jen ( '',)
Jul 03, 2011 | Sony Cameras
My navman s30 keeps turning off
most likely the GPS needs the battery replaced, when the battery starts to go this is what happens.
Jul 29, 2010 | Navman S30 Car GPS Receiver
Battery smelt and the machine become bigger and broken
Betteries are gone becuase of overcharging or compltion of life. Require repair from a qualified personnel.
Jul 15, 2009 | Digital Blue iUbi Blue Digital Media...
Soney cybersthot dsc-s30 charging issue
I replaced the battery. The new one keeps a charge and lets the ac adapter charge the battery. I plan on purchasing a new battery and recycling the old one.
Feb 17, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
22 people viewed this question
 Grubhead
Grubhead
