Question about LG Washing Machines
Uneven load code comes up - LG Washing Machines
    Problem Solver:
  • 6 Answers
This may be due to underloading , machine uneven on flooring . possible excess wear on suspension legs .
Posted on Jan 23, 2013
We keep getting the UL (unbalanced load) code on our Whirlpool Cabrio washer (model # WTW8800YC1). Is there a way to determine if it is the bearings or the suspension rods?
You can check the bearings by axially moving the drum against the axis in which it spins, backwards and forwards on a top loader, or up and down on a front loader.
More likely to be a suspension spring broken, or come unhooked.
Try the washer with two bath towels to check for uneven loading.
Dec 29, 2016 | Whirlpool Washing Machines
My washer keeps stopping at the spin cycle and says UL for uneven load. The load is not uneven and evey load does this
Hi.
UL is displayed when there is a balancing problem or when balancing sensor is defective.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual also try distributing the load
. If that does not work there are internal faults that may trigger the fault code. The balancing sensor and the electronic control board must be tested. The machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Jul 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UE error...the washer will not spin.
this code refers to uneven load on spinning, even load by adding or removing cloths
Jan 16, 2011 | LG WM-2277HW Front Load Washer
When i have an uneven load how can i make the
you should have a pause or stop button, if dial push button in, rearrange the clothes to be more balanced in the washer, then push the pause button again, or if dial push it in......hope this helps.....
Jan 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spin cycle
You have an uneven load... ( not kidding here).. If you remove and/or reposition the clothes inside . and restart.. does it spin up and complete the cycle? ( probably yes).. but if no.. please elaborate on what it does or doesn't do so we can help.. I've experienced the same problem when my daughter tries to do her entire weeks worth ( maybe longer) of clothes in one load.. The quick fix is usually to down size the amount being washed.. Hope this helps you...
Aug 29, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
NEC Washing Machine when it comes to spin cycle stops and just beeps with the 'OE' light flashing.
Well, what does that mean? Old Engine? Octopus Entering? Oily Electricity? Darn. No clue from that light, is there?
My guess is that it thinks there is an uneven load. Assuming that you've straightened your load, I'd say it must be a bad uneven load sensor. And unfortunately I don't know where that is located. So I guess I'm not much help. Sorry.
Jul 16, 2008 | Washing Machines
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
24 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
