SEAGATE ITE RAPTOR 3.5 MAIN BOARD V2R1 SATA TO USB INTERFACE buy
SEAGATE ITE RAPTOR 3.5 MAIN BOARD V2R1 SATA TO USB INTERFACE where i can buy
3 Suggested Answers
SOURCE: Hi There I am trying to locate the raptor 3.5"
Here's your solution, I had the same problem. Purchase Thermaltake Black Widow PC Gaming Hard Drive eSata + USB Docking Station (part number: ST0005U). I got mine at Best Buy for $55, but I'm sure you can find it online for much less. Good luck - trust me this works..... oh and by the way, dont buy a SATA-to-USB cable because your USB port on your PC does not provide enough power to the hard drive and you won't be able to access your drive.
Posted on Aug 06, 2011
paulmarratt
  • 5 Answers
dos any one no the coler code to soter the cabal direk ly to the bord if you can i can do the work to fix them
Posted on Nov 19, 2012
Interface seagate barracuda 7200.7 200GB drive sata to usb 2 forum
Hello. You are correct that there are no jumpers, however, when you connected the SATA cable to the Internal hard drive, did you notice there were two similar connectors. One was for the SATA the other, longer one is for the POWER for the drive. If your SATA to USB has both connectors make sure they are both installed properly. Be careful you don't break those little plastic tabs because they are not warrantied. If the drive does have power and spins up then it may not be initialized (formatted) and will need to be initialized using START, Administrative Tools, Computer Management, Disk Management. or just click on start and type diskmgmt.msc in the RUN box.
Hope this helps..
Nov 04, 2012 | Seagate Barracuda 7200.7 200 GB Hard Drive
I had four broken DVRs of same type, I want to use their HDD in raid strip in PC, but they are DVR HDDs (Seagate Pipeline HD.2, ST3250312CS) and they are not initiable in PC. Is there any way to use them? ...
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.
Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
Jul 05, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
My computer malfunctioned and I took out the hard drive to try and retrieve my files using a USB cable. I am stuck
Your hard drive has no USB port, it has a (seral) SATA 3 GB/sec interface, currently and
by far the most popular used on laptops, and also desktop computers. The SATA (serial advanced technology interface) 3 GB/Sec is version 2.0 of the SATA standard.
So, you'll need another laptop or desktop with a spare SATA 2.0 port, or a spare SAS (Serial
Attached SCSI) port, since SATA drive may be attached to SAS backplanes, as well as SATA backplanes. For a laptop, you may need to use the eSATA connector/cable
(see http://en.wikipedia.org/wiki/ESATA#eSATA for eSATA technical specs and a photo).
May 13, 2011 | Seagate MOMENTUS 7200.4 320GB SATA SATA...
Apr 13, 2011 | RPM 20PK 150GB RAPTOR SATA 10000 16MB...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
I have a Seagate ST1.2 8 GB drive in an I/O Magic enclosure with a flexible USB connector that stopped responding recently. I suspect the USB connection has failed, not the drive. I would like to recover...
Yes, the disk-drive can be "transplanted' into a new enclosure.
Just be sure that you buy the correct enclosure (SATA-interface if your disk-drive has a SATA-interface, or parallel-ATA if your disk-drive has a parallel-ATA interface).
Feb 01, 2011 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Hi I have a seagate raptor 3.5" V2R1 external hard drive and the socket on the board that you plug the cable ( USB on one end) into from your PC has come of the main board...can the board be...
Dec 06, 2010 | Seagate Computers & Internet
Seagate Freeagent Go 500 GB won't work.
im having the same problem tried a new drive enslosure but thats not working it says the drive is 2tb when its 500gb, which tells me the sata to usb board is fried so its not comunicationg with the computer even though the drive still spins, so im going to buy one of those sata to usb docking stations but ill have to take the drive out the case which will void the warranty. the last thing ill try is to buy a refirbished freeagent go and swap the sata to usb board, this is important, i have 200gb work of music that i need and i dont have a backup, ill post my efforts asap.
Jun 24, 2009 | Seagate FreeAgent Pro 500GB External USB...
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
680 people viewed this question
David Payne
David Payne
