Toshiba E2830C error code C970 - Office Equipment & Supplies
3 Suggested Answers
  • 132 Answers
SOURCE: Dear all error code c970 Hvt
in the drum there is a pin make sure the drum shaft is making contact if the problem persists change the drum and blade make sure the main charge carona is not broken and the plastick hanger is not broken
Posted on Feb 15, 2011
tonesmaker
  • 60 Answers
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Posted on Jun 12, 2011
Toshiba e 282 is error code C970
C970 is charging issue. Check main charger, t/s block unit
Aug 24, 2015 | Toshiba Office Equipment & Supplies
Toshiba e232 is error code C970
Code C970 Description Process related service call
High-voltage transformer abnormality: Leakage of the main charger is detected.
Aug 09, 2015 | Toshiba Office Equipment & Supplies
Error c970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
there is no reset code for c970 ...the cause of this is the second transfer roller grounding contact..check if there is foreign materials on the contact ...this error is grounding contact problem
Error code c97 what this ?
There is no error code c97 but there is a c970
c970 is a hgih voltage transformer abnotmality.
there are many things that can cause this most needing a trained technican
some common causes are:
a broken/shorted charge grid/needle elecrode
broken/defective high voltage power supply
Dec 27, 2012 | Toshiba E-Studio167 Copier
How can i fix the error code C970 on my toshiba e-studio 230?
Nov 01, 2010 | Toshiba e-Studio 350 Copier
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
Toshiba e-studio 232 code C970
c970 show code on main screen of the toshiba e-studio 352 machine plz solve it urgently
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
49 people viewed this question
jasbo
jasbo
