Question about Sharp R-202EW Microwave Oven
Sharp R-4A56 microwave oven dead
The microwave is completely dead, no clock or functions. I am thinking it may be a fuse. Is this likely, and how would I change the fuse? Thank you, Terry
  • 2 more comments
  • terry smith Jul 23, 2007
    Should have mentioned, I already checked the circuit breaker, the outlet is hot.
  • creekwoodpla Jul 22, 2008
    Sharp R-4A56 microwave oven buzzed upon starting then went dead.  No problem with circuit.  I've located the fuse but inside the oven there is a note to replace the monitor switch.  Is this really necessary for me to complete the repair?  I can't locate a part number for this model.
  • chiouhappy Jul 30, 2008
    I have exact the same problem. Our Sharp R-4A56 microwave oven buzzed when starting then went totally dead. Is this worth repairing?
  • Anonymous Mar 18, 2014
    the microwave is completely dead - no power
  • 84 Answers
Did you check your circuit breaker to be sure that it wasn't tripped?
Posted on Jul 23, 2007
SOURCE:
Unit is completely dead
please check the fuse - you will be able to locate it on panel. - replace it and the pcs is ok --
Feb 23, 2014 | Samsung SMH9187 Microwave Oven
MICROWAVE PROPLEM
follow this next steps, use the VOM, and fix it. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some modelsbcd93e93-ccee-45ab-ba5c-70967b1ff19b.gif
Jun 11, 2013 | Sharp R-1874 Convection/Microwave Oven
Boiled and egg and killed the microwave. Any way to revive it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ii
Apr 03, 2010 | Sharp R-320HQ Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Hi, My microwave oven stopped working after I came home from four days of vacation. The digital clock works. What could be the problem? The turn table does not work. Is there any danger opening back of...
if the clock is working then the fuse is fine. if the fuse goes bad the unit would be completly dead. no their is danger removing back panel. as you said make sure the unit is inplugged., however some electrical parts inside hold a charge until discharged.the board could be bad, the door latch or switches could be bad.
Sep 19, 2009 | Sharp Microwave Ovens
Unit dead Unit is dead - suspect blown fuse
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
May 20, 2009 | Sharp R-1880LS 850 Watts Microwave Oven
Microwave oven stoped worling
maybee,but no.Most microvaves have that problem over a few years because of the heat stress over the fuse and it starts to ware.You can get it fixed by a handyman or a maytag repair man.But are better off buying one for around 60-110 dollars
glad to help
Dec 11, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave stopped working
Chances are the thermal cutout (thermal fuse) on the magnetron opened up. It may or may not also indicate a bad magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 28, 2007 | Sharp R-202EW Microwave Oven
Open Questions:
Sharp R-202EW Microwave Oven Logo
492 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
