Need a manual for a Varian FTIR Scimitar 800 - Televison & Video
3 Phase star connection with earth or not?
You think it is wise to work on a machine that if connected wrong, can cause dead for the one that touch this machine?
I think you not only need the skills to connect this, you also need certification. At least in my country you must have. I know, I used to be. But not anymore, because I'm officially retired.
Jun 24, 2014 | Varian Mdc High Vacuum Research Gas...
How do I connect star connections?
From what you have said, I am guessing you have discovered the ground point. That "floating neutral point" is the ground and should be connected. If the cable isn't connected, it isn't as safe. In general it is precaution.
Elisa Jed ' http://www.abaileyplumbing.com
Brake fluid leaked out . now no clutch
You neeed to fix the leak. That is bad for a hydraulic system. If you fill the clutch reservoiir up and bleed it, you might pick up a little clutch back, but it won;t be optimum until the leak is stopped.
Nov 17, 2012 | 1986 Reliant Scimitar SS1
Ford 2,9 EFI ignition wiring diagram needed, fitted to a Reliant Scimitar
If you have the TFI module on the distributor or the firewall, or up front in the airflow by the radiatior- it is the likely fault. It is what triggers the coil to fire.
When you replace it, make sure to use plenty of heat sink compound- the better compound resembles the color of clear RTV silicone prior to curing- it just has the color- do not use RTV, use the grease. The white material often used in factory production gets clumpy over time and is not as good.
Jul 07, 2012 | Cars & Trucks
Consumo de gasolina y diagrama de las mangueras de vacios
Especifica el motor y el sistema de inyeccion que tiene instalado ya que estos varian deesa forma te podre alludar
Nov 12, 2010 | 1997 Nissan Pickup
Yellow lcd hdtv screen
You have a defective light engine and Hitachi is aware of it. Here's what you need to do...we just went throught this about a month ago. Call Hitachi's customer relations department (not regular customer service0 at 800-654-7013 and tell them what the TV is doing and that you believe you have a bad light engine. Now at first, they will act as if they know nothing about this problem. They will however give you some names of certified dealers in your area to come out and diagnois the problem. Once the tech comes out and tells you that you have a bad light engine, only takes about a minute once they see the problem, call Hitachi back at the number I've listed and tell them what the tech said. Hitachi will call the dealer directly and they will send the part directly to the dealer. Once the dealer gets the part (new light engine) the dealer will give you a call and will come out and install it in your home.
Here's the kicker. If your TV is not still under warranty, Hitachi will pay for the part (part cost around $1500) but you will have to pay for the install. Our TV is 3.5 years old and was not under warranty and our install cost $400...worth it to us since we spent $3600 on the 60 inch 3.5 years ago. If your TV is still under warranty, Hitachi should pay for the part and install but again, regardless if your under warranty or not, Hitachi WILL COVER THE PART. Please do not let any dealer or store take advantage of you and tell you that you have to pay for this $1500 part. That is happening but most certified dealers will not do that.
Hitachi has not recalled this part (although they should) but they are replacing it for free once you have the tech come out and confirm that it's a bad light engine.
Please deal only with Hitachi's customer RELATIONS department and not customer service. The 800# I listed above is directly to customer relations. Hitachi's customer service department will not help you at all.
Once our light engine was replaced, the set is like BRAND NEW! Good Luck!
Jan 03, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink Screen
You have the infamous "red cloud" as we call it and nothing you personally do will fix it. Here's what you need to do...we just went thgrough this about a month ago. Call Hitachi's customer RELATIONS department (not customer service) at 800-654-7013. Tell them what the TV is doing and that you believe you have a defective light engine. Now, they will initially act like they have not heard of this problem but they have. The will however give you the names of some certified dealers in your area to call. Once you have a tech out to confirm that you have a bad light engine (this will take the tech less than a minute once you turn the set on) call Hitachi's customer relations department back and tell them you have a bad light engine. All of a sudden, they will acknowlege the probelm exist and will Hitachi will call the dealer direct to confirm that's the problem.
Once they confirm the problem with the dealer you used directly, they will send out a brand new light engine and Hitachi will cover the cost.
Here's the kicker. If your TV is not still under warranty, ours was not, Hitachi will cover the part (cost around $1500) but you will have to pay for the install. Our install cost $400 but worth it to us on a $3600 TV that has been great up until the light engine issue. If you're still under warranty, Hitachi will cover the part and the install. DO NOT let any store or dealer tell you that you will have to pay for this part. Hitachi is replacing it with brand new light engines for free...you just pay the install.
Please deal only with the Hitachi customer RELATIONS department at the number I've listed above. That is the direct number to Hitachi's customer relations department. Hitachi customer service will not help you at all!
Once our light engine was replaced, and the tech replaced it in our home and did not have to take the TV to the shop, our TV is like brand new again! Good Luck:)
Dec 31, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink hue on dark screen
You have a defective light engine. We just went through this and here's what you need to do...there is hope. Call Hitachi's customer realtions department at 800-654-7013 and tell them what the set is doing and that you have a defective light engine. Now, they will initially act like they've never heard of this but they have. They will however give you the names of some certified dealers in your area to call. Once you call the dealer and a tech comes out and confirms that you have a bad light engine, takes less than 1 minute, call Hitachi's customer realtions department back at the number I listed above.
Once you call and tell Hitachi that you had a tech out, all of a sudden, they will acknowlege the problem and they will call the dealer you used to confirm it. Once they've confirmed that it is a bad light engine, Hitachi will send a BRAND NEW light engine directly to the dealer and the dealer will call you to come out and install. HITACHI WILL COVER THIS PART regardless if you're still under warranty or not.
Here's the kicker, if your not under warranty, Hitachi will cover the part, but you will have to pay for the install. Our install was $400 but worth is to us on a $3600 TV we've only had 3+ years.
DO NOT let any dealer or store tell you that you will have to pay for this part. Hitachi will cover the cost of the part (around $1500). Hitachi has not recalled this part (they should) but they are replacing it FOR FREE.
The 800 # I've listed above is directly to Hitachi's customer relations department. Please deal with them and not Hitachi customer service. Customer service will not help you at all.
Once our light engine was replaced, our TV is like BRAND NEW! GOOD LUCK:)
Jan 03, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
