Question about Canon PowerShot S3 IS Digital Camera
On switch won't work / turn
The operating switch will not turn to the on position
    Genius:
  • 1,019 Answers
Hello,The rotary switch that you refer to is not available from Kodak.It is mainly sold as the complete rear housing assembly which is the rear half of the camera.You may contact me at hounddogellie@gmail.com
I currently have several of these assemblies available if you have someone that can change it.Hope this helps.
Best Regards,Russell
Posted on Jan 23, 2013
I have a 95 Honda civic and I was driving on the freeway went to get off and right when I was down shifting it wouldn't move out of neutral even though the stick was in the second gear position. So I...
To clarify something you said, the accessories should go off when the key switch is in the start position.
Are you getting power to the coil and the computer when the key switch is on and in start ?
May 30, 2013 | Cars & Trucks
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
1997 nissan pathfinder le 3.3l - Brake lights won't turn off - replaced stop switch and relay combo already. any ideas?
The brake switch will stop all current to the brake lights. As soon as the brake pedal moves just off of its fully up position, the switch makes contact and passes current on to the brake lights. You can operate it by hand to check if everything is right. izzit adjustable? The switch is the last thing in the path to the brake bulbs, so it has to work right, right off the brake pedal!
Sep 29, 2012 | 1997 Nissan Pathfinder
Suzuki VL125 starter motor won't turn, ignition on, cutout in correct position, neutral light showing, hold clutch lever in, on operating starter switch I just hear a click from under the seat. If
Locate the solenoid (the thing that clicks) and peel back the rubber boots from the terminals, put a large screwdriver or metal rod between the terminals. If you get sparks and the starter turns the solenoid is faulty. If you get sparks but no starter then check the wire down to the starter and make sure it hasn't been worn through and is shorting out. If that is ok do a final check bu jumping directly to starter ie positive to starter and negative to frame. If the starter still fails to turn it need replacing
Jun 25, 2012 | Suzuki Motorcycles
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
Parking brake light won't go off after releasing brake lever
Park brake lights normally operate by a small plunger type switch the turns off when the level or pedal is placed in the off position. Over time the spring in the lever weakens and placing the lever in the off position no longer depresses the switch. The switch can sometimes be adjusted to make better contact, or the switch bracket can be bent so the lever and switch make proper contact.
Feb 17, 2012 | 1992 Toyota Pickup
Can't shift out of park
This might work for you guy's replace the brake light switch
Easy step by step tutorial watch the video. im sure it will help.
MERCURY MARQUIS STUCK IN PARK
http://youtu.be/fgUn1TuHu-0
Dec 24, 2011 | 2000 Lincoln Town Car
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
1996 jag xjs , the battery is dead , I need to jump start it but the trunk won't open ,battery in the trunk , can it be jumped from under the hood ? and why won't the trunk open even with a key ?
The trunk latch is operated by a solenoid which it requires power to operate. since the batery is flat then it won't work. I'm not sure where the positive terminal is under the hood but you can connect the positive lead to the alternator wire terminal, and the negative lead can be connected any where on the engine.
Good luck......
May 21, 2011 | Jaguar XJS Cars & Trucks
Canon PowerShot S3 IS Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
