Question about Sewing Machines
I can use my janome mylock serger without the upper looper breaking on first stitch. I have rethread it many times...can anyone help
  • Sewing Machines Master
  • 7,365 Answers
Is the looper itself breaking or is it the thread that's breaking?
Posted on Jan 24, 2013
  • 55 Answers
SOURCE: my janome harmony 9102D serger I think is out of
i suggest you get a tech to re-time your machine. timing is complex on an overlocker and if not done correctly you will probably break a looper.
scott.
Posted on Jul 27, 2009
bargainbox
  • 1388 Answers
SOURCE: Euro pro serger model 101-548
3 thread overlocking (serging) is no different t 4 thread, except you remove one or other of the needle threads.
The stitch width is then controlled by two variables,
the manual width dial selector, and
your choice of either the right or left needle
Suggest yo play with width selector on a scrap of your project fabric to achieve the look you are after.
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: Janome MyLock 644D
Yes, the model I used had a self threading lower looper. Just put the thread into the guide and flick the switch
Posted on Jun 11, 2008
  • 1116 Answers
SOURCE: My serger will only sew a few inches, then the
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Posted on Apr 01, 2010
  • 5 Answers
SOURCE: white speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! rick_coccia@yahoo.com
Posted on Sep 16, 2010
Huskylock 905, bought new, just love it. Changed thread, first time ever the blue looper keeps breaking. Rethreaded x 20. Still breaking. Sounds good, cleaned regularly with canned air, etc. Help!
Hello Christine,
Since I can not be there with you to guide you, here is video showing the threading Detailed How to Thread Viking Huskylock 905 Serger
However a few additional tips:
1. Make sure to use good quality thread.
2. Make sure to use fresh thread. Thread does have a shelf life.
3. Make sure that the tension, stitch length, and blade position are at the correctly set for the type of stitch required.
4. Make sure that the 'lower looper' thread is sitting "over" the 'upper looper' and "over" the 'upper looper thread'. This is VERY important.
5. Make sure that the threads are not caught-up/wound-up/stuck around anything.
This should solve that phantom challenge. Please let me know how the stitching works out, or come back with more information/questions
Please give me a thumbs up if this was helpful.
Happy serging
Sewingirl/
Jun 04, 2018 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
Juki-654DE/654 serger red thread from looper breaks need to figure out how to resolve
Really difficult to say without seeing it. Generally, breaking thread indicates a mis-threading issue. When I've had this problem, it usually requires unthreading the entire machine. ALWAYS RAISE the presser foot and rethread from the beginning. Be sure to thread EACH THREAD IN THE ORDER specified (upper looper, lower looper, then needles). Also, when threading each thread, give each thread an extra little tug where it goes through the tension disk to make sure it is seated fully.
serger breaking thread Google Search
Feb 19, 2018 | Sewing Machines
Adjusting tension on overlocker
overlockers and sergers are annoying in that every time you change materials and threads they must be re-tensioned.
Get a scrap piece of material. Thread your machine correctly according to the instructions in your manual. If no manual most sergers are threaded, upper looper, lower looper then needles from right to left. Make sure you thread with the presser foot UP.
You want to balance the stitches Begin by adjusting the looper dials, you want them to meet right at the cut edge. Then adjust your needles. Keep doing test seams until you have them balanced. If you are a novice... try threading with each thread point having it's own color. That will help you identify which thread is giving you fits.
Have fun.
Oct 15, 2012 | Janome MyLock 634D Mechanical Sewing...
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
Thread 1 keeps snapping
Is it possible the thread might be too old? If so, it might tend to break easier than normal. Also if it got wet.
Jan 03, 2018 | Janome MyLock 644D
I cut the chain thread by mistake, how do i get it back? Am new to this
Rethread the machine. Do the loopers first, then the needles. If you ever break a looper thread, you have to undo the needle threads, rethread the looper thread and then rethread the needles.
Apr 22, 2011 | Janome MyLock 644D
My janome harmony 9102D serger I think is out of
scott.
Jul 21, 2009 | Janome Harmony 9102D Mechanical Sewing...
Retiming Mylock Serger 234D
Ooh, I've heard it is difficult timing a serger because there's more involved than a sewing machine.
You can try looking at videos and web sites:
serger timing Google Search
Nov 16, 2017 | Janome MyLock 634D Mechanical Sewing...
Lower looper
It is impossible for a looper to come unthreaded if you are holding one end and the other is still feeding off the spool. Somewhere a thread broke - must be either the upper looper or the needle. Try completely re-threading your machine. Many machines have an "order" they prefer to be threaded. Try starting from the right tension guide and work to the left.
Sep 17, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
