Question about Samsung WB150F SMART Long Zoom WiFi 14 Megapixel Digital Camera - White
Why is My samsung wb15of camera blurry
As soon as I turn in onto the normal smart mode to take a picture, it is blurry and the picture then comes out blurry
SOURCE: My camera is blurry..and it takes blurry pictures..How can i fix this?
some camera's require you to hold down the shtter button half way to focus. sometime setting get messed up also, make sure it is set to automatic in the set up menu
Posted on Sep 29, 2007
Coldcut
  • 1554 Answers
SOURCE: pictures either very white/red for Samsung Digimax S700 digital Camera
The iris in the center of the lens may be stuck open or damaged.
you can look inside the front a focus/zoom/ turn on off and see if it opens and closes.
Posted on Apr 02, 2008
MJS_1
  • 150 Answers
SOURCE: samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Posted on Apr 24, 2008
REL123
  • 15 Answers
SOURCE: fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Posted on May 14, 2008
robmcd27
  • 423 Answers
SOURCE: Blurry video recording
Since the camcorder returns to the auto shutter setting and the auto exposure setting when it's switched into Night Capture mode, I would say that might be your problem.  Change your shutter and exposure settings. To do this, switch to Camera mode, turn the menu dial to the setting you wish to change then press enter.  You may have to play with the settings until you get the desired picture. Remember, faster shutter speeds for faster action (stop action), and longer exposure settings for darker situations. Let me know if you need more help.
Posted on Feb 16, 2009
My samsung i8510's camera is always blurry, the
You cant just point and shoot!
Press the shutter and then wait until afew seconds until its finished.
May 15, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
Feb 16, 2009 | Samsung Video Cameras
Hi i have a nikon d40, but all my pictures are coming out blurry. i don't have it long and it was working perfectly. any help would be very grateful.
Actually that's perfectly normal operation. They turned out soft or a little blurry because the shutter speed was too slow for you to handhold, the aperture was wide open, or you moved the focus after focus was obtained. In auto mode, there are very few things you can set, so there isn't any setting it back to normal. You could try using a flash. But it probably boils down to proper holding technique and proper exposure.
You could benefit by taking a basic class on photography. Learn how to use your camera in the Manual mode and you'll be able to exactly figure out why your pictures in auto mode didn't come out looking as sharp as you thought they should. If you don't have time for or can't afford a basic class, your manual is a good place to start.
Dec 02, 2008 | Nikon Cameras
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Blurred pictures
Check that the auto focus and auto exposure is turned on. Check that the camera is not in the macro mode for normal picture taking.
It is possible that there is a defect that is not allowing proper focus. In this case your camera will require service.
Jerry G.
May 05, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Fuzzy pictures
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Pictures either very white/red for Samsung Digimax S700 digital Camera
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Samsung WB150F SMART Long Zoom WiFi 14 Megapixel Digital Camera - White Logo
143 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
