Question about Lionel Toy Trains Smoke Pellets
What is lionel smoke pellet tamper used for? Why needed?
I see the wood tamper that came in some maintenance kits for Lionel locomotives that used smoke pellets. Just not sure why the tamper is needed. Revivig my dad's train and thought you just drop the pellet in the smokestack.
    New Friend:
  • 161 Answers
Yes, you do just drop the pellet in...
But if there is any kind of crud built up in the
smoke stack, it may not allow the pellet
to seat on the heating element. Thus the
tamper is included to allow you to push
the pellet all the way down. If you don't
have one, a piece of wooden dowel the right
diameter can be used.
Posted on Jan 31, 2013
  • Traindoc Jun 16, 2014
    The tamper was designed to let you push down any build up in the stack without damaging the heater windings. If you use a wooden dowel, be careful not to damage the heating element.
I have a Lionel 7796 New York Central. The remote blinks a constant red and it does not operate the locomotive.I thought it was the remote so Lionel sent me a new remote but the same problem exists.
The locomotive is not receiving the single from the remote . You need to paire them. In the Manuel should be intuitions for pairing. Hope this is some help.
REDEAGLE
Dec 17, 2017 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
What does my lionel 6110 use for smoke. Smoke pellets or fluid.
  • The Lionel 6110 Scout Engine came stock with a pellet smoke generator. Sometimes these get converted so the smoke puffs more out the front. But the way it came out of the box is pellets.
Regards, Tony
May 18, 2011 | Toys
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My...
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Apr 29, 2017 | Lionel Toys
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 | Toys
Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Lionel Toy Trains Smoke Pellets Logo
206 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
