SPOT SL5W09 Spot Light Logo
Posted on Jan 23, 2013
FULL CHARGE LAST 5MIN. MAX
THE BATTERIES DIE IN LESS THAN 5 MINUTES AFTER A FULL CHARGE.THE RED LIGHT ON TOP BLINKS RED WHILE THE SPOTLIGHT WILL STROBE A FEW TIMES THEN QUIT WORKING.
Billthetoolm
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Jun 03, 2016
Billthetoolm
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
26825
Points
48
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
2helpful
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know
r
2answers
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
1helpful
Both batteries show full charge but don't last 10 minutes. Only had the tool for less than a year.
rechargeable batteries can build a memory, if you use it say for 5 minutes and then put it back on the charger - then the next time you use it for 5 screws and put it back on the charge - see where I am going
Over time the rechargeable batteries "learn" they only have to work for 5 minutes ( dang my son was that way)
You need to fully drain them and recharge them fully several times might take 10 times.
We have a program in our shop that when you are done with a battery it goes in the flashlight until dead, dead, dead then to the charger. I have batteries that are 10 years old and still work almost like new.
You may have to replace yours but it is worth a try
1helpful
2answers
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Usually the red light is on to indacate the batteries are being charged,now the green is the only light that is on
The green light on the charger usually indicates that the batteries are fully charged and you are ready to go. Does the controller show the batteries are fully charged? Can you operate the power wheel chair for several hours? If so, you are good to go.
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
1helpful
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Top SPOT Camping, Backpacking & Hiking Experts
john h
Steve Pack
Steve Pack
Stacey Wells
Stacey Wells
Level 1 Expert
Are you a SPOT Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
