Only some keys work on Snugg keyboard - Computers & Internet
Why aren't detachable keyboard keys a/z/q working?
I can only guess but sounds like you need to buy a new keyboard .
Dec 30, 2015 | Tablets & eReaders
Tip
How to troubleshoot keyboard issues?
<b>Summary:</b><br /> Keyboard issues are relatively easy to troubleshoot. If the cu has another keyboard available then try that keyboard or if the cu has another system avaialble then test the keyboard on that system. Remember when the keyboard is unplugged the system will usually need to be rebooted before it will work again.<br /> <b>Wireless Keyboard:</b><br /> If only some of the keys don't work skip to the section <b>Some Keys Don't Work</b> below.<br /> <ol> <li>Resynchronize the keyboard. Press the connect button on the keyboard for 5 seconds. Then press the connect button on the receiver for 5 seconds <li>Change the batteries. <li>Try reseating the receiver if possible. <li>Try positioning the keyboard closer to the receiver. <li>Skip to the section <b>Generic Troubleshooting</b> below. </li></ol> <b>Some Keys Don't Work:</b><br /> <ol> <li>Check if any of the num lock key, shift lock key, etc are causing the issue. This is especially prevalent on laptops which don't have a distinct numeric keypad. <li>If it's only the multimedia or hotkeys that don't work then try installing the specialized multimedia keyboard software that came with the system/keyboard. <li>Try reseating the keyboard and rebooting. <li>Go into <b>Accessibility Options</b> in <b>Control Panel</b> and check that <b>Sticky Keys</b>, <b>Filter Keys</b> and <b>Toggle Keys</b> are all switched off. <li>Check if the problem occurs in the BIOS. A good screen to test with is the create BIOS password screen if the keys don't work here then a new keyboard is in order. <li>Continue on to <b>Generic Troubleshooting</b>. </li></ol> <b>No Keys Work:</b><br /> <ol> <li>Try reseating the keyboard and rebooting. <li>Try power draining the system. This can be particularly effecitive with a laptop. <li>If this is USB try a different port. <li>Try entering BIOS - if you cannot get into BIOS then the keyboard probably needs to be replaced. <li>Go on to <b>Generic Troubleshooting</b> below. </li></ol> <b>Generic Troubleshooting:</b><br /> <ol> <li>Try uninstalling and reinstalling the keyboard driver and reboot <li>Try system restore back to before the problem occurred <li>Check for malware or 3rd party software that may be interfering with the function of the keyboard. <li>FFR or replace/upsell a new keyboard. </li></ol>
on Jan 17, 2011 | Computers & Internet
What is the problem why the arrow keys functioning differently.
Disconnect and reconnect your computer keyboard, then restart your computer.
Sometimes a poor connection can result in keys not working on your keyboard
Update the device driver for your keyboard by going to the manufacturer's website of your keyboard, and then download and install the latest driver matching the brand and model number of your keyboard.
Disconnect your keyboard from your computer and inspect the pins in the keyboard connector if you have a PS/2 connector.
The PS/2 connector for your keyboard has six pins, which connect into a PS/2 port of your personal computer, to allow for communication to and from your keyboard.
Straighten any bent pins you may find, by gently using a ballpoint pen.
You must replace your keyboard if you see broken pins.
Try testing your keys using a different application, such as another word processing program. Keys like the function keys on your keyboard labeled F1 through F12 may not work in one application but will work fine in another.
Clean Under Desktop Keys
Disconnect your standard desktop keyboard, then press down on a key not working.
Slip a car key or a flathead screwdriver underneath the key.
Twist the screwdriver or car key until the keyboard key pops off.
Use a damp cloth, moist cotton swabs or compressed air to remove dust, hair, and food crumbs under the key.
Use only water or rubbing alcohol to moisten the cloth and cotton swabs---other cleaners can damage the plastic of your computer.
Position and press down on the key to snap it into place.
Repeat this for all of the keys to clean underneath them, if necessary.
hope this helps
Oct 14, 2012 | Unotron S5100KG Keyboard
Compaq CQ60 some keys not working
The keyboard maybe faulty.
Connect an external keyboard to youe laptop and if all the key work on this keyboard then most like the laptop keyboard is faulty.
If this external keyboard also malfunctions then the keyboard controller chip on the laptop motherboard is faulty and it would not be worth repairing as this is an old model laptop.
Mar 04, 2012 | Compaq Presario CQ60-212US Notebook
My car seems to have a dead battery, nothing lights up. However the battery is not dead, I have it tested twice and it works. Also I can jump start the car to work fine. So I have a dead car, the power...
yes. check you battery terminals and connectors clean them then tighten them bk up snugg prob a bad connection due to corrosion or loose connectors.
Jan 29, 2011 | Ford Focus Cars & Trucks
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
NewTouch Keyboard 200 function keys do not work on a MacBook Pro running 10.5
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Oct 10, 2008 | Logitech USB (967199-0100) Keyboard
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Keyboard
No keys on my keyboard work. Cause: This issue is often caused by either a bad keyboard, bad interface board, and/or bad motherboard.
Answer: Disconnect the keyboard from the computer and connect another known working keyboard to it. If this is a PS/2 keyboard and connecting multiple keyboards or a known working keyboard to the computer PS/2 port does not work unfortunately it's likely that the PS/2 port is bad. Because this port is part of the motherboard this will require that you replace the motherboard. Alternatively if replacing the motherboard is too costly or not an effective solution you could also consider using a USB keyboard if USB ports are available on the computer.
Not all keys on keyboard work.
Reference number: CH000305
Not all keys on keyboard work. Issue: Not all keys on keyboard work.
Cause: This issue is often caused by a bad keyboard or software preventing these keys to be pressed.
Additional information: This document contains information about troubleshooting a keyboard that has some functioning keys. If no key on the keyboard is working see document CH000955.
Solution: Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or safe mode and test the keyboard in DOS. Information about getting into safe mode can be found on document CHSFAFE and information on how to boot to DOS can be found on document CHDOS. If it appears that a substance has been spilt into the computer, please review document CH000303. If all above suggestions have been completed or if you are not running Windows, it is likely that the keyboard and/or keys are bad and it is recommended that the keyboard be replaced with a new one.
Read and follow instructions, Please dont for get to Vote/Thank You.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
