Question about Keurig B70 Coffee Maker
How do i install my water filter
I can't see where it goes
    Master:
  • 253 Answers
In the resevoir under the handle you need to pull out.
Posted on Nov 25, 2013
Samsung side by side fridge/freezer ice and water is not working after filter change
If your water and ice maker are not working, you may not have turned your water valve back on. If your water valve is turned on, try rotating your water filter further so that it completely locks as it may not be installed all the way. Once it is completely installed, press the "water" button for approximately three seconds until it turns blue. If this does not solve the problem, you may have a bad filter, here is a replacement filter that you can purchase to install into your refrigerator: http://www.freshwatersystems.com/p-3658-swift-green-sgf-dsb30-compatible-samsung-da29-00003b-refrigerator-filter.aspx
Jun 23, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
I just installed a new GE MWF filter in my refrigerator. Now, after a few cups of water, it's emitting a high-pitched whine when we get water. And the water volume goes down. Is the filter defective?...
It sounds like that may be the case and thier is something wrong with that filter..do you still have the old one to put it back in temporarly and see if it works as it used to beofre changing filter
Gene
Aug 23, 2011 | Refrigerators
Just installed a new filter and 1 month old sand from defective filter. Removed the cardboard cover used to prevent sand from going into pipe. Piped everything together and no leaks. When I try to run the...
Too much sand or wrong type of sand in the tank are two possibilities; should tell you on the side of the label how much sand to put in but generally it fills to about half way up the tank body.
Are you getting sand back in the pool at all? If not it is unlikely the sand is the issue since too small a grain would pass thru the laterals and get to the pool.
Have you used any clarifiers in the water? Over-dosing with a clarifier can literally turn the top of the sand bed into mortar impeding the flow of water.
John
Jul 09, 2011 | Hayward SAND FILTER, PRO SERIES
Hot water temp seems ok but flow has got slower. Does not appear to be a problem with the diverter valve, as it is not bypassing. (this valve was changed last year) Mains cold pressure is fine. Boiler...
The last sentence in the description of the problem, says it all.
I too, have had the problem, Tony. But, in addition, to the hard water,I discovered something that I didn't know. In our home's water system (our home is 30 years old) , someone prior to our ownership had installed a 6' section of galvanized pipe (possibly a repair). If you're not familiar with galvanized pipe and what hard water (High iron content) will do, it rust from the inside out. This 6" piece was almost totally clogged with rust and corrosion. This is also the effect it can have on a water heater. Especially, the sacrificial anode rod inside the heater (if it's an electric water heater) That's why it's so important to drain and flush your water heater, at least once a year.
I mention all of the above, because you very well, may be experiencing the same issue. The way to resolve it requires a little detective work on your part. Check you piping to see if any is galvanized pipe, rather than copper or PVC. Keep in mind, that the sink fixtures, may very well may be galvanized, if your home is 30 or more years old. If you find any, I highly recommend replacing it, before something goes wrong in the middle of the night or while you and your family are away from home. If you hard water is a result of using a well, place a whole house water filter on the main incoming water line. It does not have to be a charcoal filter. And to make your water more palatable, install an automatic water softener. For me, it was all money well spent.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Heating & Cooling
Changed water filter, and now no filtered water comes out. Water had slowed, and it stopped making ice, so replaced the filter like always, and now no filtered water comes out at all Bought the same...
Don't know which filter you use, so this might not work. Try reversing the filter to see if it got installed incorrectly.
If not, make sure the the water line didn't get kinked and that the valve is open.
Jun 08, 2011 | Kenmore Refrigerators
Hello. please tell me where the water filter is located? Thank you
they don't have filters in the machine, if you have a filter look in the basement,find the water feed line going to the fridge and see if the plumber installed a filter.if he didn't shut off the water valve going to the fridge,cut the water line and install a filter.you'll need to buy a filter and a couple of connectors to connect the filter to the water line.hope this helps.
May 01, 2011 | Sub-Zero 690 Side by Side Refrigerator
Keurig B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
