Question about Maytag Epic Z 6.7 cu. ft. Electric Dryer
Epic gas dryer mod#-MG09700SQ0, cycle knob only registers heavy duty and cannot adjust temp. How can I fix?
Need to know how to get panel off to check wiring, replace parts.
  • Maytag Master
  • 17,130 Answers
Check this link for tips: Control knob
Posted on Jan 24, 2013
FixinFax
  • 3085 Answers
SOURCE: my maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Posted on Nov 25, 2009
  • 65 Answers
SOURCE: I have a Maytag front load Mod. # MFW9600SQ1. When
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Posted on Jan 30, 2010
Testimonial: "It remedied the issue :) Thanks"
  • 3 Answers
SOURCE: maytag epic MFW9800 control knob pin broke
kevin
Posted on Mar 20, 2010
  • 3741 Answers
SOURCE: Washer does not allow hot
did you checked the temperature of the water.if the water is not that hot for heavy duty load then hot water will not enter the machine. yes if the water is getting hot for normal /regular cycle then it will work properly.but for heavy duty load it requires more hot water.check the temperature of the water. checkout .keep updated.thanks.
Posted on Mar 22, 2010
  • 86 Answers
SOURCE: Maytag heavy duty super capacity
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Posted on Jul 16, 2011
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Trying to find kenmore elite heavy duty king sizecapacty plus ultraquite pac gas clothes dryer mod#11o72082100
It is no longer produced. Try eBay or craigslist?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 74602 Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Light piolit
Hello dreas15
I need more information.
What's the model number.
How old is it? Today's dryers have electronic ignition.
Waiting for your response! I will respond right away!
Huuum
Sep 22, 2008 | Dryers
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag Epic Z 6.7 cu. ft. Electric Dryer Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
