Miele washing machine 6065 stuck on main wash programme , unable to clear or reset . any ideas ?
  • Washing Mach... Master
  • 17,130 Answers
Switch off machine for some time maybe overnight. Press and hold on panel buttons to drain off voltage. when powered hold on start/stop/pause button. If the program does not reset it be fault in the memory or the processor.
Posted on Jan 24, 2013
  •  Roy Tilley
    Roy Tilley Jan 24, 2013
    hi, i unplugged motor plug connector on pcb to create a fault , fault appeared then i reconnected plug connector . this allowed display to revert to normal and all programmes now work . not sure what caused the lock out in first place though . many thanks !
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
skyblue67
  • 71 Answers
SOURCE: Miele W4840 is LOCKED
hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
How do i reset the error code F51 on my miele touchtronic w 3035
haha
you need to make all legs an level
turn off the mains
level it with a spirt level on the top
then its level
then turn it on
and the error should clear by its self
Mar 04, 2015 | Miele Washing Machines
How to reset miele washing machine
Most resets on Miele is simply unplugging for 5 or 10 seconds. This does not clear faults - simply resets the CPU
Aug 16, 2014 | Miele Washing Machines
Miele 6065
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 23, 2013 | Miele Washing Machines
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Miele W487WPS Washing Machine
unplug machine, drain water manually by leaving the out let hose down gravity will let the wate out unless its blocked.Close Ire.ps. door should open .reset,and try again
Feb 24, 2008 | Washing Machines
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
