Question about Kenmore Washing Machines
My elite he3 will not drian/spin with out pushing the drain/spin butten.
Mod. 110 44832 200 SER. csp 1603588
  • Kenmore Master
  • 17,129 Answers
Possible that the auto mode is not working due to fault in the processor or the memory. Try and check with another program cycle and if the same fault repeats it seems to be a suspect. Make sure to clean the Inlet and drain filter and check the water flow pressure.
Posted on Jan 24, 2013
SOURCE: Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Had same problem. Followed advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
Posted on Dec 13, 2007
jsrock516
  • 5911 Answers
SOURCE: ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Posted on Jun 12, 2008
reg501
  • 413 Answers
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
Posted on May 26, 2009
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite 40512900 stays at 7 minutes
well often when it hits the last ten min of a cycle it is trying to drian more times then not it isnt or it hasnt senced it has drianed so odds are that your drian pump not drianing or you have a bad pressure switch. i would start with the drain pump often it has a filter that get clogged and can be gottin to from the front
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
Should the drain pump on a kenmore elite he3 spin freely if operateing correctly (the inpeller)?
Yes.... without the motor attached.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore washer won't go to final spin
The motor won't like the 50 Hz power because it was designed for 60 Hz. The same goes for any transformer that powers the electronics. Changing the motor and transformer for local parts might solve the problem, but likely to be quite costly. It might be better to pick up a machine made for this market. If you can find and use a 60Hz generator, you could see if that fixes your problem. Good luck!
Aug 21, 2009 | Washing Machines
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso washing machine that won't spin and drain, it has an error code of F-3, but I can;t find my manual. any help
After setting up washer I hit the start butten, washer filles up and befor it will start it will start to beep and the lights flash and I have to hit the start butten agin befor it will start to wash.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
