Question about Coby MP-C543 MP3 Player
Stuck on blue screen
Stays on blue screen does'nt shut off
How to format my dell optiplex 740... its nt getting formatted the normal way it only has usb ports and i want to format it because it shuts down suddenly on startup....a blue screen appears and it shuts...
put in the installation cd or dvd, run the dvd and after it will ask to do a fresh install and then will ask you to format!!! Or remove the hard drive and connect to an other computer and format
Mar 21, 2012 | Dell Computers & Internet
Pandigital novel white stuck on blue screen
everytime i turn on my pandigital tablet it goes to blue screen and stays on there, until the battery dies, everytime you turn it on it goes to the blue screen and stay on there what should i do?
Mar 02, 2012 | PANDIGITAL Novel 7
Iphone4S screen stays blue, won't shut off. nothing works
Hi
Try hard resetting.This restores factory settings on your phone.Be warned though,it will also erase all user data like video images and songs etc.
Here's a video tutorial on how to go about it.
Hope it helps.Thanks!
Feb 19, 2012 | Apple iPhone4 4G iPhone 4
Iphone4 screen goes blue and won't shut off
Hi
Try hard resetting it.This procedure may erase all changes effected on the i phone
Press and hold the power button and the menu button.Wait until the apple logo appears.
Feb 19, 2012 | Cell Phones
The projector is stuck on the blue screen. It will let me change the input but it will still stay on the blue screen even though everything else is on and working.
Hello!
"blue screen" means: picture is all blue, but there is a signal coming through? Do you see channel logo? Menu? If so, blue CRT or CRT board is at fault. Depends on the age of the set. If set is fairly new, then try to bang on the neck of blue tube with rubber screwdriver hands. Very gentle! While set is working. If you see the retrace lines and TV shuts down then, CRT is at fault. If not, try to play with blue "screen" control of "focus block". Black plastic module with bunch of thick wires attachad to that. Has 3 "focus" and 3 "screen" controls. For each of the tubes. In many cases you'll be able to adjust "blue" down to normal. Usually, those controls are smeared with white paint and hard to turn by hand. Loosen those with little pliers, then adjust manually or via small "phillips" screwdriver. If nothing helps: CRT board is at fault and must be replaced or repaired. In this case you won't see any characters on blue CRT, just solid "blue".
good luck,
Alex.
Jan 20, 2012 | Sony Televison & Video
When i get to the loading screen on disk 2 it gets stuck on a black screen. i tried cleaning both the console and the disk but it still gets stuck on the black screen
Alot of the newer playstation console's won't read the old black or blue labels. Try getting it resurfaced. Cost you about $2 at the nearest game store.
Apr 25, 2009 | Sony PSone Console
Coby MP-C543 MP3 Player Logo
44 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
