Question about Mk Diamond MK - 660 Electric Tile Saws
Saw does not cut tile straight - Mk Diamond MK - 660 Electric Tile Saws
4 Suggested Answers
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 8 Answers
SOURCE: tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Posted on Jul 22, 2010
carmin77
  • 113 Answers
SOURCE: My MK370 tile saw has
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Posted on Jun 03, 2011
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
Feb 18, 2014 | Felker FRS-38 Tile, Marble & Granite Rail...
Cuts are bowed
I heard that the rod that it rides on, may be bent. This is the rod, that you normally adjust, to get your straight cut, parallel to the blade. One mans solution was to turn the rods, so the bend of the rod, was vertical, rather than horizontal. You may want to look into ordering new , hopefully straight rods, from QEP too.
Jul 13, 2013 | Qep Tile Tools 83200 24inch Bridge Saw
Saw is not cutting straight
Make sure the miter is lined up at 90 degrees to the blade. The fence has to be parallel to the blade and the blade tight. Cuts should be straight if the piece is held firmly and you move at the proper speed. Good luck!
Mar 05, 2011 | Dewalt D24000S Wet Saw With Stand
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
Will not cut straight anymore, blade wobbles blade is not old
There are a couple reasons why the blade is wobbling. Either the diamonds are glazed over because the material you are cutting is way to hard or the blade is very thin and when metal gets hot it expands and when you make a longer rip cut it will tend to wobble. I sell blades for a living and i can almost gurantee this is the reason
Dec 15, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile saw not cutting straight
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Mk Diamond MK - 660 Electric Tile Saws Logo
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
