Question about Samsung P50HP 50 in. LCD TV
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
I am trying to split the AV connection into AV1 AND AV2...However, the TV giving only one option as AV. How can be resolved in order to connect two devices.
    Top Expert:
  • Samsung Master
  • 74,211 Answers
You can select its other 2 av inputs by pressing the AV button on its remote control.
Posted on Jan 23, 2013
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
  • 92 Answers
SOURCE: Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Posted on Mar 28, 2009
SOURCE: connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
  • 121 Answers
SOURCE: I am having problems with
Your problem is typical of Samsung LCD TVs. The capacitors on one of the internal boards are rated at 10V and should be higher. If you open the case, you'll see bulging capacitors. If you can handle a screwdriver and soldering iron, you can actually fix it yourself with a few capacitors from an electrical supply store. Simply read the specs off the bulging capacitors and get a higher voltage-rated replacement. For exmaple, if the capacitors say "1000uf 10V 105C", you would replace them with "1000uf 35V 105C" or similar rating. Or an easier method: Recently, Samsung themselves have been making repairs as it is such a widespread problem. Call Samsung at 1-800-726-7864 and they may just repair it for free, even if its not under warranty.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
Posted on Feb 23, 2011
SOURCE: new device not found usb1
download the firmware and problem solve T-MSX5IBRC-1004.4
Posted on Sep 02, 2011
Sinotec TV, I'm trying to connect dvd or Ps it says no signal
Check your AV cables. when the AV cables are connected to the TV, select AV mode on your TV. Remember you might have more than one AV mode ie AV1, AV2, AV3.........
May 21, 2016 | Televison & Video
New dvd player wont play when I change channel to av. All plugs in correctly. I have an indoor antenna but get every channel. What is wrong?
Try a different channel on your TV Some times it may be AV1 or AV2 on the TV that you have to connect to. The DVD should also show a "start up" screen on the TV to show you that it has connected properly.
Apr 19, 2015 | Televison & Video
How do I hook up a dvd player
yellow, white and red wires usually connected to the same name same colors on both devices.
Does the tv need to be on a certain channel? YES, try change to all ex: VIDEO 1, VIDEO 2, DIGITAL, ANALOG, HDMI or any according to tv sysem
Oct 27, 2013 | Seiki Digita Seiki LC46G82 46 in. LCD HDTV...
Vedio not coming on tv
Have you changed setting on TV to AV, or AV1 or AV2 whichever you have it plugged in to? You did plug in to input correct?
Apr 28, 2012 | Heating & Cooling
HCP4363W - No color from AV1, AV2 or ANT inputs
You might have a problem with the intenal board or the AV connection onto the board. Have a TV repair center check the board and the connection.
Apr 27, 2012 | Samsung HC-P4363W 43 in. TV/DVD Combo
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
When i tried with TV AV buttons with DVD it is not working for AV1 and AV2 only audio is available no video
Did you unplug it from the wall. try unplugging if from the wall for two days and try it again.
Dec 22, 2007 | Polaroid TTM-2401 TV
Samsung P50HP 50 in. LCD TV Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
