Question about Dell Optiplex 755 Desktop Desktop Computer
When i try to boot computer it tells me diskette seek failure
Then I press F1 and it tells me no boot device available
    New Friend:
  • 12 Answers
Something in the hard drive system is failing.
check that the cables are pushed in all the way
go into the BIOS & check if it detects the hard drive name & model
If it does not detect the hard drive, then you need to replace the drive.
If it does detect the drive, then the Master Boot Record (MBR) is likely corrupted. There are Windows commands that can fix this, but I think it varies with Window versions. You can google to repair the MBR for your version of Windows. If the MBR is damaged, there's a good chance more is damaged, so MBR might not be the only problem.
If you can't or don't fix the MBR, you will require a full format and reinstall of Windows, applications, printers, etc.
Posted on Jan 23, 2013
  • Dell Master
  • 2,878 Answers
Go into BIOS and change the boot order to CD, then HD, and so on. Just remove floppy from being first.
Plus make sure BIOS does recognize hard drive so it boots and gets rid of the no boot device.
clokker
  • 253 Answers
SOURCE: Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Posted on Nov 22, 2008
jell587
  • 447 Answers
SOURCE: Dell Inspiron 531s Windows Vista
If you are given the option to go into the setup (F2) try to disable the floppy disk drive or move the hard drive up in the boot order.
Posted on Feb 21, 2009
Bat1956
  • 585 Answers
SOURCE: keyboard failure and diskette drive 0 seek failure
How old is the computer, could it still have warranty? USB ports are often protected with fuses. Some latest stuff has resetable fuses, but many are one-time that do not heal. Did you try the keyboard in the front USB's The thing of biggest concern though is that this happened in coincidence, meaning you may have a motherboard hardware failure. (the reason I mentioned warranty)
Posted on May 20, 2009
FixinFax
  • 3085 Answers
SOURCE: boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Posted on Jan 06, 2010
Crankstart
  • 696 Answers
SOURCE: when i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Posted on Jan 08, 2010
Diskette 0 seek startup failure
restart your system and press delete to enter the bios mode and change the boot options set 1st boot device as cd/DVD rom and 2nd boot device as HDD if you are not using floppy drive just disable it. After finishing the changes press f10 to save the changes and exit
Feb 24, 2012 | Microsoft Windows Vista Home Premium with...
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
Boot up screen says "diskette drive 0 seek failure"
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Feb 21, 2009 | Dell Inspiron 531s Desktop Computer
Nov 22, 2008 | Dell Dimension C521 PC Desktop
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Dell Optiplex 755 Desktop Desktop Computer  Logo
59 people viewed this question
Alun Cox
